convertible back windows help |
Aug 20, 2010 - 11:20 PM |
Enthusiast Joined Apr 7, '09 From cali Currently Offline Reputation: 0 (0%) |
ok so the wiring diagram does not show information on the back windows for a 98 vert GT
i rolled driver side back window down the other day ...and it wont go back up i have power all the way up to the plug behind the back panel i can hear clicking for the relay when its goes down .... im guessing there maybe a relay to go up ...when i try to push up it wont go up and there is no clicking .....i haven no idea where the relay is mounted in this car based on my diag the Up relay is messed up ...any one know the location ? my awesome quick fix was to unpin the plug on the back panel and repin the wires backwards doing so i was able to get the window to go up and now it wont go down ... |
Aug 23, 2010 - 2:44 AM |
Enthusiast Joined Apr 8, '03 From New York City Currently Offline Reputation: 0 (0%) |
Aug 24, 2010 - 1:51 PM |
Enthusiast Joined Aug 29, '09 From Ohio Currently Offline Reputation: 7 (100%) |
try taking the switch apart and clean the contacts. This is a chronic problem with verts. I have to clean my switch contacts about every 3 months.
Aug 24, 2010 - 11:26 PM |
try taking the switch apart and clean the contacts. This is a chronic problem with verts. I have to clean my switch contacts about every 3 months. isnt the switch ...the switch send power up to the plug behind the divers side speaker cover ........which leads to who knows where ...cuz there is just metal bars and plates i cant get around it |
Aug 30, 2010 - 6:52 PM |
Enthusiast Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
I have the diagram. There is NO relay, the switches are connected to the motors directly (via connectors, of course, which could be loose or bad).
There is one MAIN POWER relay for all the power window circuits. As long as any window is working in any direction, that relay is good. |
Sep 3, 2010 - 1:10 AM |
Enthusiast Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
Im with ajlee. Your contacts are bad. Trying cleaning the contacts on the rockers and base.
Sep 3, 2010 - 7:58 AM |
Enthusiast Joined Apr 20, '10 From Virginia Currently Offline Reputation: 0 (0%) |
I had that issue also my rear driver side window would go down but not up. Cleaned the contacts like it said on here and worked like a charm. Still ****ed with my top tho lol
Lo-Fi Version | Time is now: November 26th, 2024 - 9:18 PM |
