Tranny list .. LSD INfo ? |
Aug 21, 2010 - 6:54 PM |
Enthusiast Joined Apr 7, '09 From cali Currently Offline Reputation: 0 (0%) |
i still have unclear info about transmissions
in the 6th gen Celica they came with 1.8 L 7A-FE 2.0 L 3S-FE 3S-GE 2.0 L turbo 3S-GTE 2.2 L 5S-FE what is the transmission code for these models of engines it came with ? in the 5th gen they came out with 1.6 L 4A-FE 2.0 L 3S-FE 3S-GE 2.0 L turbo 3S-GTE 2.2 L 5S-FE what is the transmission code for these models of engines it came with? i see there is a s51 , s53 , s54 ,A140E.....im still trying to find a compatible one for my 6gen 5sfe manual This post has been edited by chinamandrift: Aug 25, 2010 - 8:15 PM |
Aug 21, 2010 - 7:33 PM |
Enthusiast Joined Jun 12, '09 From Hull, England Currently Offline Reputation: 0 (0%) |
i still have unclear info about transmissions in the 6th gen Celica they came with 1.8 L 7A-FE 2.0 L 3S-FE 3S-GE 2.0 L turbo 3S-GTE 2.2 L 5S-FE what is the transmission code for these models of engines it came with ? in the 5th gen they came out with 1.6 L 4A-FE 2.0 L 3S-FE 3S-GE 2.0 L turbo 3S-GTE 2.2 L 5S-FE what is the transmission code for these models of engines it came with? i see there is a s51 , s53 , s54 ,A140E.....im still trying to find a compatible one for my 6gen 5sfe manual Gen 6 manual transmissions as far as i know 7A-FE - C52 3S-FE - S54 3S-GE - S54 3S-GE SSS none beams - E56 3S-GE SSS beams - S54 3S-GTE - E154F 5S-FE - S54 -------------------- |
Aug 21, 2010 - 8:03 PM |
Enthusiast Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
best one you can buy is the E153 LSD from the MR2 and convert it to FWD, its pretty simple and is the best you can get for a FWD 6th gen.
Aug 21, 2010 - 8:10 PM |
best one you can buy is the E153 LSD from the MR2 and convert it to FWD, its pretty simple and is the best you can get for a FWD 6th gen. not really much point unless you intend to get big power gains from the lil' 5S-FE -------------------- |
Aug 21, 2010 - 8:41 PM |
Enthusiast Joined Aug 12, '09 From Orange Beach, Alabama Currently Offline Reputation: 6 (100%) |
Sweet! This is something I have always wondered myself!
This would make a good sticky if it gets more info in it! -------------------- Failing to prepare is preparing to fail!
Aug 23, 2010 - 4:51 PM |
7A-FE - C52 3S-FE - S54 3S-GE - S54 3S-GE SSS none beams - E56 3S-GE SSS beams - S54 3S-GTE - E154F 5S-FE - S54 in addition what i found from a shop U.S only FWD 85-89 celica 2.0L 3S-FE had S53 89-93 celica 2.2L 5S-FE had S53 89-91 celica 1.6L 4A-FE has C52 91-93 celica 1.6L 4A-FE has C52 93-99 celica 1.8L 7A-FE had C52 93-99 celica 2.2L 5S-FE had S54 |
Aug 24, 2010 - 12:53 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
check further down the page
http://www.6gc.net/forums/index.php?showto...68176&st=80 I hope to have a gearbox id, ratios and y/n LSD etc info sticky thread shortly. -------------------- |
Aug 24, 2010 - 5:14 PM |
good news ...i sourced out a Transmission from an unknown 3S series engine from japan at a JDM shop ....
i took my S54 USD 98 5sfe to the shop to compare ....everything is almost the same the cv axles line up ...input shaft has 20 splines.. everything is in the proper place except the rib design on the trannies are different ...when i get 150 bucks i will post pictures of the transmissions and a complete tare down |
Aug 25, 2010 - 8:13 PM |
ok more news WTH
so some S54 from japan has LSD ..this is tripping me out cuz i got this tranny for 150 but the tranny i bought has this notice the inside cross shaft .. i cant see through it ...does it mean i have lsd? if it is what kind ? i know nothing about the car this came out of...when i bought this ... it was already out of the car sitting on the floor.. i was told this was from a 3S series motor thats all the info i got here is the USDM S54 tranny from my Celica notice the cross shaft ...its alot more narrow ...and i can see all the way through the transmission im taking both transmissions apart tomorrow ..but the suspense is killing me ..can anyone confirm ? This post has been edited by chinamandrift: Aug 25, 2010 - 8:15 PM |
Aug 26, 2010 - 2:23 AM |
reading through my link............ I have a feeling you might have a S54-06D (Helical LSD) 95 - 99
but would rather people who have done a SS-III BEAMS & tranny swap just to confirm it, since it could be a S54-06A non LSD, just the difference between the 5S-FE and 3S-GE non lsd transmissions. -------------------- |
Aug 26, 2010 - 5:07 AM |
The "bar" check only works on MR2 tranny's/LSD's, as far as i'm aware, the "bar" actually means nothing at all it is just a coincidental physical difference on those tranny's. The only ways to know for sure is to dismantle and check or find the box code as Rusty says; S54-06D - LSD, S54-06A no LSD
Aug 26, 2010 - 9:05 AM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Very interested as I wish to keep my s54/3S-GTE combination cause I like the gearing better for the racing I do [tho a longer 5th gear would make me happy]. If I can get an LSD in my trany I'm all about that.
BTW - You guys DO KNOW the MRS LSD will work for our s54's - if you can find one. -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 26, 2010 - 9:46 AM |
Very interested as I wish to keep my s54/3S-GTE combination cause I like the gearing better for the racing I do [tho a longer 5th gear would make me happy]. If I can get an LSD in my trany I'm all about that. BTW - You guys DO KNOW the MRS LSD will work for our s54's - if you can find one. the part number for the TRD LSD for the S54 box is 41301-ST804 they're often floating around on ebay -------------------- |
Aug 26, 2010 - 9:54 AM |
Oh really?!? Thanks Tom_SS2
Any confirmation that will work in a USDM s54? It should right? And BTW - I'm very positive a friend who is a very knowledgeable service tech at a Yota dealership told me the BEAMS Celicas came with an e153 tranny. That doesn't make it true obviously but perhaps something for you guys to consider. This post has been edited by DEATH: Aug 26, 2010 - 9:54 AM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 26, 2010 - 10:24 AM |
BEAMS did not come with e153, that has been discuss on this same topic earlier and prove has been shwon that it in fact came with s54.
and yes, the MR-S LSD will work in a S54, they are easily available on eBay and cheap to get in UK as all MR-S had LSDs ( hellical BTW ) -------------------- |
Aug 26, 2010 - 10:32 AM |
I don't know a hell of alot when it comes to the differences between types of LSD - is Hellical good?
How does each of them work? Hellical Clutch type 1 way 1.5 way etc -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 26, 2010 - 11:12 AM |
you have mainly 3 types of LSDs
Hellical Viscous ( vLSD ) Clutch type Hellical LSD is a gear LSD power is transfer to both wheels by the gears, one draw back of Helical LSDs is that both wheels have to has some resistance ( touching the ground ) for the LSD to distribute the power, if one wheel is in the air or on ice, the gears will spin the wheel with no toruqe twice as fast, this is the reason why hellical LSDs are also refer to as Torsen ( torque Sensitive ) RWD drivers overcome this by applying the eBrake when one wheel looses traction, the brakes will act as a resistance on the wheel with no traction, splitting the power back to 50 / 50. Hellical LSDs can be aggressive as with a sudden torque application to one wheel the other will grab instantly. Viscous LSDs they are sealed units, that contain a silicone fluid in it, along with LSD couplin ( metal ), as one wheel spins at a different ratio in relation to the other, the different in speeds will generate friction and thus heat, once the silicone gets hot it will expenad moving the LSD couplin together and thus sending the power to both wheels to bring them to the same speed. Viscous LSDs are maintance free, and the only thing to worry about when using them is not to get them overheated, overheating will destroy ( change the properties ) the silicone and the LSD will not work, so system will act as a regular open diff from that point and on. Most manufacturers prefer vLSD in FWD application because of the smoothness with which the power gets transfer. Clutch type, name says it all, it has clutches inside it, thsi LSDs are very high maintance, under real racing they need to be rebuilt after each race or so, they can come in different ways like 1.5 and 2 way this clutches are not intented to be installed on FWD cars, they are aggresive, Note, I wrote this right before taking my lunch so I'm hungry and have not much time, there may be spelling errors or some information crossed out lol, but I'll revise it later or if you guys feel something is not right, corect me. -------------------- |
Aug 26, 2010 - 1:03 PM |
Feel free to edit - I'm adding this to my Car Engineering files [yes my work spills over into my car building hobby - so what?]
Awesome Info Culp - Thanks alot. Any way I can get you to give me more when you're at home bored? -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 26, 2010 - 7:07 PM |
sorry for the wait guys ...i still have both the JDM unkown S54 and the USDM GT 98 S54 .....i plan on taking it apart today but ...since the teachers are not there ...i cant take it apart ....they have the special tools i need for it ....im going to check gear ratios too ...so stay tuned
Aug 29, 2010 - 2:02 PM |
1 way: lsd action is only when engine torque is applied to the diff
2 way: lsd action is applied when torque from the engine OR the driveshaft(s) act upon the diff 1.5 way: anywhere between the two (lsd locks up only partially when the driveshaft applies torque to the diff) drawback to viscous (possibly) the fluid in the VC coupling can apparently go bad with normal use (~60,000 miles) *unreliable source* -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Lo-Fi Version | Time is now: November 27th, 2024 - 9:52 AM |
