> GT/Beams AC, Compress amps
post Aug 23, 2010 - 2:36 PM
sugarfree
Joined Dec 21, '05
From dallas
I messaged tweak who i originally got my harness completed by but i think it takes him a while to respond and im in TX and its hot as EFF here. Well anyway, short background, the harness was converted from a GT to a Beams red top. My ac is not working but the compressor and fan turn on when jumped. The plug behind the glove box is not plugging into the OEM GT compressor amp. Would it have been possible that the beams plug for the compressor amp was left on the harness and not spliced to a GT plug? How can i fix this?
post Aug 23, 2010 - 4:14 PM
the plug from the gt and beams harness that plugs behind the glove box are identical....
post Aug 23, 2010 - 6:12 PM
sugarfree
Joined Dec 21, '05
From dallas
For some reason mine isn't plugging in? The harness doesn't look like that part has been touched either, meaning it's like the 6th gen harness is still in tact.... It's not plugging in for some reason but they look the same....Any ideas?
post Aug 23, 2010 - 6:34 PM
Imawakeyo
Joined Apr 20, '10
From Virginia
sure it's a GT because the ST one is dif i think
post Aug 23, 2010 - 6:59 PM
sugarfree
Joined Dec 21, '05
From dallas
Well the original was GT, nothing was ever ST on the car.
post Aug 23, 2010 - 7:20 PM
sugarfree
Joined Dec 21, '05
From dallas
And this plug i don't know where it plugs or if it needs to be plugged in:
The connector for the amp is bigger than the amp itself by two slots.... Can someone help?
post Aug 24, 2010 - 11:20 AM
mkernz22
Joined May 10, '10
From MA
the yellow ones are the airbag system! DO NOT PLUG THEM IN WITHOUT UNHOOKING BOTH WIRES FROM THE BATTERY!
As for the plug, I should have it, but it may take me a day to find it, how exactly is it not fitting?
Also, as for the circuit board, I never saw that when I was taking anything off my parts car, but I'll check it out
post Aug 24, 2010 - 2:53 PM
sugarfree
Joined Dec 21, '05
From dallas
Its underneath the glove box. Its upside down. Yeah, youd have to look for it. If you could, see if its the same as mine. It's not fitting because one side of my connector has 2 more squares than the amp has.
post Aug 24, 2010 - 7:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
that one in your hand needs to be plugged in, the other end is on the harness, its probably caught up behind the core there. when i rebuilt my 5S-FE i did the same thing and no AC, once i plugged that in, i was good to go
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 25, 2010 - 4:49 PM
sugarfree
Joined Dec 21, '05
From dallas
Anyone else?
post Aug 27, 2010 - 9:04 AM
what you are holding in your hands, is it the harness tweak sent you? that plug is not part of the engine harness.
because the plug you are holding looks like the plug n1 and the one on the harness should be n2
on another hand why have you disconnected the a/c. those plugs i did not touch when i did my swap/
post Aug 27, 2010 - 9:07 AM
the only plugs you deal with, are the ecu, the opening circuit relay next to cpu, one single plug of the a/c which is n2 upstairs and the main plugs which are these
post Aug 27, 2010 - 5:14 PM
sugarfree
Joined Dec 21, '05
From dallas
Are you saying that i am missing a whole harness? Below is what i have:
I have no other plugs that i can find....
post Aug 28, 2010 - 11:45 PM
i dont get it why did you disconect all those cables. I dont see the plug n2 in my pic. Are you sure its not hidden in all that mess.
try to conect the plugs as my picture and see whats missing...
post Aug 29, 2010 - 1:13 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah, yous missing a harness
post Aug 29, 2010 - 10:29 PM
sugarfree
Joined Dec 21, '05
From dallas
I didn't disconnect the plugs. This guy, which he is actually on this board did the swap for me. I don't talk to him anymore because of these reasons. Okay cool thanks for the clarification. I really need it especially here in TX hot heat!
post Aug 29, 2010 - 10:47 PM
mkernz22
Joined May 10, '10
From MA
so here is the harness that you need, that I do have.
I'll just send you a bunch of wire harnesses that came from that area lol
your missing it:
This post has been edited by mkernz22: Aug 29, 2010 - 10:57 PM
post Aug 30, 2010 - 4:47 PM
^^^ now that makes more sense
Lo-Fi Version Time is now: January 10th, 2025 - 5:27 AM
