> Tires stores piss me off.
post Aug 24, 2010 - 11:36 AM
mkernz22
Joined May 10, '10
From MA
So I'm in need of getting new tires for my stock rims because they are getting kind of bald on the inside. I've gone to a few places already and they don't have the exact 205/55/R15 tires there, but they do have 205/60/R15's. They keep telling me it'll throw my speedometer off by a few miles an hour and that my braking distance will be semi reduced. I just want to know if that is true or if it's just B.S.
post Aug 24, 2010 - 11:38 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Idk i was told that too, i went from the stock 15s like what you have to 17's 225 45 17R and honestly braking is a bit different, the ride is a bit different, but my speedo is the same.
post Aug 24, 2010 - 12:08 PM
mkernz22
Joined May 10, '10
From MA
just found one place that has some Dunlop Direzza's in stock so I'll be going there tomorrow to get them put on (hopefully)
post Aug 24, 2010 - 12:11 PM
richee3
Joined Jun 29, '08
From Denver
They most likely aren't lying to you. The Celica has an unusual tire size. Most tire manufacturers aren't offering any options for us anymore. Most auto manufacturers are using larger rims now, not 15" rims, and those that are still using 15" rims are getting a bigger sidewall than a 55 series. If you switch to a 16" or 17" rim, you'll be able to more easily find tires. My IS 300 uses a 215/45/17 tire. A 45 sidewall, if you missed that. Yet I can still find more tires and cheaper than anything for a Celica.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 24, 2010 - 12:17 PM
mak5603
Joined Oct 20, '08
I have 17's and when i pass those "you are going this fast" radar sign, my speedo's a couple off.
2014 Toyota Rav4 XLE
post Aug 24, 2010 - 12:32 PM
mkernz22
Joined May 10, '10
From MA
Well I also have 18 inch rims from my parts car that I'm cleaning up and putting on in the spring and it made me think, why the F**k does is matter that much to them that I need the factory spec size on my stock rims? It's so dumb. I mean I would figure it would be off my a few mph lol I never realized how strict some places were with that crap.
post Aug 24, 2010 - 12:39 PM
mak5603
Joined Oct 20, '08
yeah, thats lame they straight up wouldn't do it. I just got a warning, as with a lot of aftermarket parts. "For track use only" etc..haha
post Aug 24, 2010 - 7:28 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
A 60 serious side wall is fine instead of 55. I used those on my car for a while and i didn't notice a difference.
It actually reduced the 4x4 look a bit at stock ride heights
My Celica!
post Aug 24, 2010 - 10:49 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Yeah it throws your speedometer off, because it's calibrated to a specific rotational size. When you start getting bigger wheels/tires the circumference changes and it throws off the speedometer.
And the math is like this - with "old" being 205/55 and "new" being 205/60
Speed Comparison:
Old front tire revolutions per kilometer: 525.
New front tire revolutions per kilometer: 508.
New front tire is at 103KPH (64MPH) when spinning at the old tire's 100KPH (62MPH) RPM.
Old rear tire revolutions per kilometer: 525.
New rear tire revolutions per kilometer: 508.
New rear tire is at 103KPH (64MPH) when spinning at the old tire's 100KPH (62MPH) RPM.
**** Photobucket
post Aug 25, 2010 - 1:31 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
tirerack.com
/thread
post Aug 27, 2010 - 11:34 PM
mkernz22
Joined May 10, '10
From MA
i actually got some Dunlop Direzza tires from a Goodyear place near my house, about $450 for the tires, with mounting, balancing, disposal, and the stems.
I think they're very good tires, they have alot of traction (can't even squeal my tires anymore) and they ride veryyy nice
post Aug 30, 2010 - 3:00 AM
windowlicker
Joined Jul 2, '08
From SoCal
this will show you the difference in what the size of tires will be with overall diameter and also what the speed difference would by going to a different size.
http://www.discounttiredirect.com/direct/b...nfoTireMath.jsp
post Aug 30, 2010 - 8:57 AM
mkernz22
Joined May 10, '10
From MA
so since i have 18 in rims from the parts car I would be better off getting 215/35/r18 over a 215/45/r18 because my actual speed will be a .13 difference with the 35 and it would be a 5mph difference with the 45?
i know that the 35's won't ride as comfortable though =/ but whatteverrr haha
Lo-Fi Version Time is now: November 29th, 2024 - 10:35 PM
