HID Help Celica 95, Need Help to install HID kits on Celica 95 |
Aug 24, 2010 - 2:47 PM |
Enthusiast Joined Aug 24, '10 From NY Currently Offline Reputation: 1 (100%) |
I want to know how you install the hid kits in the celica 95 on both high and low beams so both can be kept on at the same time. or i is it a bad idea?
Aug 24, 2010 - 4:38 PM |
Enthusiast Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Uhm should be plug and play.... Ballast and all.
Aug 24, 2010 - 6:03 PM |
when you have the low beams on, and then then you turn the high beams on, the low beams stay on with the high beams. it's how our cars are designed
Aug 24, 2010 - 8:41 PM |
I know but let say i connect all four headlights with an HID kit each would all of them work at the same time? btw whats a good cheap HID kit i can purchase
Aug 24, 2010 - 8:48 PM |
DDMTuning, its like 60$ a kit with a lifetime warranty. Depending on what model and how many watts. And i dont understand what your asking... are you asking if you get 1 Ballast can you hook up 4 headlights to it....
Aug 24, 2010 - 8:52 PM |
HID kits are for either high or lows. So you will have to buy two kits, one for the high beams and one for the low beams.
Each kit comes with two converters, one for each of the head lights. The converters just plug into the existing high and low beam plugs. I hope this clears thing up because you can't connect all four headlights to one converter. |
Aug 24, 2010 - 9:00 PM |
Ok, so your saying i need two kits which should include four converters?
Aug 24, 2010 - 9:03 PM |
yes exactly, each kit includes two converters, so four altogether.
http://www.hidxenonheadlights.com/Toyota-Celica-HID-Kits/ |
Aug 24, 2010 - 9:07 PM |
thanks!!!
Aug 25, 2010 - 1:54 AM |
Dumbest idea ever. HIDs in a halogen housing = ricer who doesn't care about the safety of others.
Save your money kid and buy projectors. Then get your fancy HID kit. Until then by some Silverstar bulbs or some Phillips bulbs. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: November 24th, 2024 - 12:36 PM |
