Closed TopicStart new topic
> Only 120Mph!!!
post Aug 24, 2010 - 8:57 PM
speed-CCNP
Joined Mar 11, '09
From Baltimore, Maryland
We should always obey the posted speed limits!!
I use a factory the JDM 3sgte ECU (ST215) and a S53 trans. At 5100 RPM in 5th gear the car drops off and bogs down every time. Is there a limiter in the ECU or something? Is it my transmission? It pull hard off the line and runs strong up to 120 then drops right off. I turned the boost in half and I only run it at 10 PSI so I'm not over boosting.
What could be stopping me each time?
post Aug 24, 2010 - 8:58 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
uhm wow
ibtl
enuf said
And im pretty sure its called a governor haha, i think you need a piggyback or stand alone to get around that.
This post has been edited by JuMPiiN: Aug 24, 2010 - 9:03 PM
mkernz22
Joined May 10, '10
From MA
yes there is a limiter!
post Aug 24, 2010 - 9:02 PM
speed-CCNP
Joined Mar 11, '09
mad.gif not cool!!!
ok, I have to get a piggy back ECU now?
post Aug 24, 2010 - 9:05 PM
Tom_SS2
Joined Jun 12, '09
From Hull, England
JDM's are limited to 180kph or 112mph in ye olde world money, you can buy delimiter/converter chips on ebay for tu'pence that slow the speed signal so that when your gauge reads 30 it means 30mph rather then kph, what this does is change the limiter from 180kph to 180mph, easy to install etc only problem is the odo will trip over in miles and not km after fitting
This post has been edited by Tom_SS2: Aug 24, 2010 - 9:05 PM
post Aug 25, 2010 - 10:13 AM
QUOTE (speed-CCNP @ Aug 24, 2010 - 10:02 PM) *
mad.gif not cool!!!
No you don't. Its a safety feature so that people like you don't end up killing themselves or everyone around them.
Slow down Paul Walker.
post Aug 25, 2010 - 10:24 AM
DEATH
Joined Dec 19, '07
From tx
My new sig!
On a track son
This post has been edited by DEATH: Aug 25, 2010 - 10:57 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
post Aug 25, 2010 - 12:13 PM
mak5603
Joined Oct 20, '08
Lol, In before Brian Spilner gets his thread locked.
2014 Toyota Rav4 XLE
post Aug 25, 2010 - 12:15 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Brian Earl Spilner, Sounds like a serial killer, Is that what you are ?
This post has been edited by JuMPiiN: Aug 25, 2010 - 2:58 PM
post Aug 25, 2010 - 12:23 PM
mak5603
Joined Oct 20, '08
post Aug 25, 2010 - 2:50 PM
racinsun
Joined Aug 13, '10
From Belfast
i think you need 17psi ecu form st205 as an upgrade if your running st185 ( im not sure about the older 1980s gt4 ), or add an rsm or even just snip afew wires .
But you may also have to sort your fuel cut defender to stop the shut down
post Aug 25, 2010 - 3:14 PM
speed-CCNP
Joined Mar 11, '09
LOL!! i love this site!!
I don't have a FCD installed. I can use an st205 ECU and instead of the ST215 ECU? But if it's the ECU then I would look into a standalone or the new e-manage.
QUOTE (racinsun @ Aug 25, 2010 - 2:50 PM) *
post Aug 25, 2010 - 6:24 PM
Tom_SS2
Joined Jun 12, '09
From Hull, England
woah whats all this jive about new ECU's etc a bloody $46 chip with 4 wires (only 3 of which are used) will do it like this http://cgi.ebay.co.uk/TOYOTA-SPEEDO-CONVER...les_CarParts_SM now mine never limits on the track
post Aug 25, 2010 - 6:27 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (Tom_SS2 @ Aug 25, 2010 - 7:24 PM) *
silly cavalier u die! im not surprised someone was stupid enough to try this
post Aug 25, 2010 - 6:49 PM
QUOTE (speed-CCNP @ Aug 24, 2010 - 9:57 PM) *
http://dictionary.reference.com/browse/hypocrisy
post Aug 25, 2010 - 6:50 PM
mkernz22
Joined May 10, '10
From MA
FAIL! lol
Lo-Fi Version Time is now: November 22nd, 2024 - 10:02 PM
