> spark plugs, GT vs ST
post Aug 25, 2010 - 3:44 AM
Hanyo
Joined Aug 16, '03
From Bay area
yet another spark plugs question.
Just did a service on my celica today and took out the spark plugs.
The old spark plugs look great considering they have been in there for around 50k miles.
Seeing the great wear I am getting on those denso plugs; I decided to put the exact same plugs in there. The car starts fine and is silky smooth now.
The problem came up when I did some further research on these plugs; They turned out to be one heat range hotter then the stock OEM spark plugs. Further detective works revealed they where designed for the 5sfe engine.
So here is the question:
Who else runs a hotter spark plugs in their 7afe? My main concern is I fill up with 87 California gasoline which has the worst octane rating compared to the other states and detonation could be a problem.
So should I toss these spark plugs out and put in the right heat range? Or should I set it and forget it considering they ran well for the 50k miles that I put on them?
post Aug 25, 2010 - 6:08 AM
fgvillegas
Joined Mar 22, '10
From Philippines
imo, use the right heatrange. not all detonation occuring is audible and that may hurt your engine.
post Aug 25, 2010 - 6:33 AM
mgnt232
Joined Mar 16, '09
woahh woahh wait! you kept the same plugs in for 50,000 miles!? and they came out like that? is that even possible? lol
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Aug 25, 2010 - 8:29 AM
They look great and look like the correct heat range.
How did you determine that they were the wrong range?
post Aug 25, 2010 - 8:49 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (lagos @ Aug 25, 2010 - 6:29 AM) *
I look them up through cross referencing them and using an application chart.
7afe spark plug
5sfe spark plug
What really throws me off is how good they look even though they are the wrong heat range. On the other side of the spark plug you can see the healthy orange/tan discoloration.
Another think I'm not too sure of is denso used the same heat range number system as NGK. Where the higher the number the colder the plug?
The 5sfe calls for PK20R11 where as the 7afe needs PK16R8.
5sfe gap is wider at .044 and the 7afe gap is .028.
I dont know which gap to set it at. I set my gap at .032 per the NGK spark plug chart.
post Aug 25, 2010 - 8:53 AM
If I remember, I'll try to check the plug part number in our parts catalog at work. That way you will know for sure if they are the correct plugs or not.
As far as gap, 32 should be good but check to see where the old ones were set at.
post Aug 25, 2010 - 8:57 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (lagos @ Aug 25, 2010 - 6:53 AM) *
i believe the previous mechanic thought my car had the 5sfe because my car is the limited edition model with no markings on it to determine st/gt.
The spark plugs where put in under 5sfe standards. I measure them at ~.04
Considering the build up on the ground strap i think they where set to .044.
post Aug 25, 2010 - 11:28 AM
Looks like they should be part number 9091901176. Only $1.46 each with the 6gc discount. smile.gif
They are listed as k16ru or pk16r11 in our parts catalog.
This post has been edited by lagos: Aug 25, 2010 - 11:29 AM
Lo-Fi Version Time is now: November 27th, 2024 - 3:33 AM
