> Radio wiring!NOW With pik of the strange wiring !!!
post Aug 26, 2010 - 10:55 AM
Frankito
Joined Sep 17, '09
From Montréal
I dont know if im the only one whit this problem...
I want to change my 94 radio for a new one...BUT! My 2 DIN radio....casette on top and CD under, have a single wiring harness! I check on other topic to find the wiring diagram for this ''mysterious'' radio...I dont think it will fit..
I have a Toyota 11708 from Fujitsu Ten and a Toyota CD Deck 34210 by Fujitsu Ten
the question is....Where I can find the good wiring diagram and will it work???
Thanks
This post has been edited by Frankito: Aug 27, 2010 - 3:41 PM
Reason for edit: dont use curse words in the titles of your threads.
Frankito!
94 GT-S
post Aug 26, 2010 - 11:15 AM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
The harness in the vehicle didn't ever change with whatever deck came standard.....it should plug in to any toyota deck from 87+ AFAIK. This also means that any harness kit you buy for 1987+ toyota will plug in....unless you have a factory amp
edit: my book is from 2002, so when I say 1987+ I mean up until 2002, not sure toyota changed it since
This post has been edited by schmooot: Aug 26, 2010 - 11:17 AM
ST205 Crew represent
Challenge Accepted
post Aug 26, 2010 - 1:06 PM
i did the radio wiring and its in the stickes
post Aug 26, 2010 - 2:28 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (schmooot @ Aug 26, 2010 - 11:15 AM) *
This is true but I have to ask you one question:
Are you trying the harness out of the back of the Radio or the harness at the factory amp on those DD systems?
The reason I ask - Alot of people don't know we have a factory amp in the better stock systems and make this mistake. I know the dip$hit who bought my car originally [or more likely his audio installer] didn't kindasad.gif You should see the wiring mess that was there till I rebuilt this car.
Try that first. It's the harness going into the stock amp from the dash harness - not the other end of the one that goes into your HU
Hope this helps
This post has been edited by DEATH: Aug 26, 2010 - 2:29 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Aug 26, 2010 - 4:50 PM
Lama
Joined May 18, '10
From Beloeil
I have the same problem. The only harness in the HU go to the amp. It's a close space. From what I have read there is suppose to have the two harness on the amp to plug the aftermarker HU. I have to look for those to by-pass stock amp.
I have foud another harness near the climtate controle unit. Is not plug to anything. I don't know what he does???
post Aug 26, 2010 - 9:05 PM
Frankito
Joined Sep 17, '09
From Montréal
I found the same plug than Lama in my car...
How I can post some pik?? I'll show you what is in my celica...
Frankito!
94 GT-S
post Aug 26, 2010 - 11:45 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the extra plug near the climate control attached to the same harness as the cigarette lighter plug are for rear quarter window and ragtop switches for convertibles only. it is not meant to plug into anything.
post Aug 27, 2010 - 9:17 AM
these are the plugs for radio after i disconnected them from the amp harness. They sell a kit to use those plugs and its self explanatory....
yes i made my own harness, but you can buy the kit. for aftermarket you don't need the amp.
You can use it, but im not even going in there on how to make you own custom harness,
i take it back, my thread was removed from the stickies...
http://www.6gc.net/forums/index.php?showto...p;hl=njccmd2002
there.
post Aug 27, 2010 - 12:43 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Nice write up man, I disagree with what the one guy said about Kenwood touch screens, I've had my pioneer for 4 years still works like its brand new. Anyways you can buy a kit its like 20 bucks and they sell it at wal mart, along with the connector. They sell it at Best Buy ( Public price no employee discount ) for like 35 or so. Depends on the deck you get/want the price varies.
post Aug 27, 2010 - 3:35 PM
Frankito
Joined Sep 17, '09
From Montréal
I have the picture now..
this is the old radio
Now I need to find a wiring diagram for this !
This post has been edited by Frankito: Aug 27, 2010 - 3:39 PM
Frankito!
94 GT-S
post Aug 27, 2010 - 3:48 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Just go buy that one piece that plugs into that. Make your worries alot easier.
post Aug 27, 2010 - 3:51 PM
Frankito
Joined Sep 17, '09
From Montréal
I when to 2 toyota dealer and they said: Cut it and find the radio diagram on the net...have a nice day!
Frankito!
94 GT-S
post Aug 27, 2010 - 7:17 PM
azian_advanced
Joined Apr 18, '05
From Calgary
it looks like you want to use the stock amplifer(s). instead of figuring out which wire is which and destroying your factory harness, you can use an amp integration harness that JuMPiiN is referring to: Metra 70-8112 Amp Integration Harness.
This post has been edited by azian_advanced: Aug 27, 2010 - 7:25 PM
post Oct 31, 2011 - 7:56 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
i have this exact same harness. is it then just matching?
yellow to yellow
black to black
red to red
solid blue to solid blue
blue/white to blue/white
what about the orange (illumination) coming out of the deck?
post Nov 1, 2011 - 9:09 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (Promasta @ Oct 31, 2011 - 7:56 PM) *
yellow to yellow
black to black
red to red
If you have the harness, yes.
From OEM to aftermarket, no where close.
post Nov 1, 2011 - 5:01 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
QUOTE (Frankito @ Aug 27, 2010 - 4:51 PM) *
Dealerships hardly ever carry adapters like that. They would rather have you order a replacement stereo through them for $900 or so. Just go to Wal-mart or somewhere like that and pick up an adapter, they still make 'em.
post Nov 1, 2011 - 8:18 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the orange wire goes to the dimmer switch near the steering column iirc. not 100% sure though. but that orange wire is just there as an option for dimming.. you don't have to use it.
post Nov 1, 2011 - 9:19 PM
Promasta
Joined Oct 2, '07
ok thanks.
still can't get this to work though. now when i test each wire in the new harness with a multimeter, the red one shows 14.3V, the rest are 0. Shouldn't the yellow one read 14V as well?
I have tried replacing the fuse on the head unit's harness, that did not work.
post Nov 2, 2011 - 8:35 AM
zonz540
Joined Jul 3, '09
From UT
Check your fuses in the engine bay. Heres the wiring colors.
http://www.6gc.net/forums/index.php?showto...94&hl=alarm
This post has been edited by zonz540: Nov 2, 2011 - 8:35 AM
post Nov 3, 2011 - 9:52 PM
Promasta
Joined Oct 2, '07
Okay, I got the head unit to turn on by connecting both the red and yellow wires from the head unit harness to the red wire of the Metra harness. However, no sound comes from the speakers. All the fuses under the hood seem good (well i didn't check the big square ones). There are 3 fuses in the interior that had no voltage, those were PANEL, TAIL and S T. Not sure what these mean or if they have anything to do with the head unit.
Lo-Fi Version Time is now: February 19th, 2025 - 11:38 PM
