2 Pages V  < 1 2
> Radio wiring!NOW With pik of the strange wiring !!!
post Nov 4, 2011 - 9:28 AM
rave2n
Joined May 29, '09
From Gainesville, FL
Do not combine the red and yellow wire to one single wire on the harness. IRC when you combine those wires, you are removing your acc power, which will make your unit forget its settings each time you turn off the vehicle.
Check your fuses.
No audio to speakers sounds like your stock amp is not hooked up correctly. Also if I remember correctly, the power for the headunit also comes from a harness on the stock amp...could be wrong.
This post has been edited by rave2n: Nov 4, 2011 - 11:12 AM
post Nov 4, 2011 - 12:26 PM
richee3
Joined Jun 29, '08
From Denver
Panel is your gauge cluster, tail is for tail lights, ST is starter. Those fuses have nothing to do with speakers. If the head unit powers on, then it isn't a fuse problem. It has to be in the wiring harness somewhere.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Nov 4, 2011 - 4:11 PM
rave2n
Joined May 29, '09
QUOTE (richee3 @ Nov 4, 2011 - 12:26 PM) *
Yea I meant fuses being he cannot get it to power without having to combine the 12v and acc.
But yea, the reason it won't power normal is because the panel fuse is blown. Replace and re-wire correctly.
This post has been edited by rave2n: Nov 4, 2011 - 4:13 PM
post Nov 4, 2011 - 7:17 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
Well the gauge cluster, tail lights and starter all work fine, so I don't know why those three are are not giving a reading.
The fuses must be okay, right?
I am presuming the battery lead (yellow wire) having no power and speakers having no power is the same problem.
post Nov 5, 2011 - 12:52 PM
rave2n
Joined May 29, '09
QUOTE (Promasta @ Nov 4, 2011 - 7:17 PM) *
Replace those fuses that are not conducting...please.
post Nov 5, 2011 - 2:02 PM
richee3
Joined Jun 29, '08
From Denver
More than likely, yes. The speakers get a signal from the head unit, so if the head unit turns on but the speakers don't have any sound, the problem has to be in the new wiring harness somewhere.
1998 Celica GT-
BEAMS Swapped.
post Nov 17, 2011 - 12:06 AM
Promasta
Joined Oct 2, '07
Problem wasn't fuses or wiring, the factory amp was blown.
So options were to either try and find a used one or hard wire to toyota's wiring. Chose to hard wire and get rid of the factory amp completely, which saved me from finding one, and plus the head unit provides more power than the factory amp did.
Bad thing is my guy charged me $100, and it took us a little over 2 hours. That factory amp is a pain in the ass to get out.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 20th, 2025 - 12:12 AM
