3 Pages V   1 2 3 >
> Engine problem, please HELP!!!, Engine only starts sometimes
post Sep 4, 2010 - 10:23 PM
hokuten3
Joined May 30, '10
From PA
i have a 5sfe engine. and sometimes the the car won't start. so im not sure what the problem is. im thinking its the computer, because it seems like the distrubutor isn't getting a spark, which would mean the computer right? what do you guys think? thanks
This post has been edited by hokuten3: Sep 8, 2010 - 8:25 PM
...5sFREAK...
post Sep 4, 2010 - 10:37 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Does the engine turn over every time?
post Sep 4, 2010 - 11:26 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
your description is way too vauge. sorry i cant help you much. does it turn over every time just not start?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 5, 2010 - 2:35 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (Smaay @ Sep 5, 2010 - 12:26 AM) *
you mean the key turning over? the key turns when i start the engine and it sounds like the engine is about to start. but it just never starts. but then sometime, when i turn it on, it starts fine, like nothing is wrong with it.
QUOTE (cyberblader1130 @ Sep 4, 2010 - 11:37 PM) *
what do you mean by "does the engine turn over?"
...5sFREAK...
post Sep 5, 2010 - 3:09 PM
battery, or check the starter.
post Sep 5, 2010 - 5:06 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (njccmd2002 @ Sep 5, 2010 - 3:09 PM) *
i know its not the battery, cause i just got a new one for it like a week ago. i'll check the starter...but i don't think its that either.
...5sFREAK...
post Sep 7, 2010 - 2:50 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check the ground...its prob dirty
post Sep 7, 2010 - 10:52 PM
hokuten3
Joined May 30, '10
From PA
so i changed the distrubutor today. and it starts now. but it still sounds like its sortof struggling to start on the first couple times when i started it. hopefully it doesn't die on me. thanks guys
This post has been edited by hokuten3: Sep 7, 2010 - 10:53 PM
...5sFREAK...
post Sep 8, 2010 - 8:26 PM
hokuten3
Joined May 30, '10
From PA
...5sFREAK...
post Sep 18, 2010 - 4:21 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
check spark timing
post Sep 27, 2010 - 4:16 PM
hokuten3
Joined May 30, '10
From PA
okay. so the engine won't start. and i checked to see if the engine is getting a spark or not, and there weren't any spark. so what could it be?
...5sFREAK...
post Sep 27, 2010 - 4:41 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
coil.
if not that, ignitor.
if not that, wiring.
if not that, ECM.
post Sep 27, 2010 - 8:18 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (stephen_lee @ Sep 27, 2010 - 5:41 PM) *
coil.
if not that, ECM.
when you say COIL, do you mean the ignition coil?
...5sFREAK...
post Sep 29, 2010 - 11:14 PM
mt953
Joined Sep 29, '10
From nebraska
have you looked at the spark plugs any?
post Sep 30, 2010 - 1:18 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (mt953 @ Sep 29, 2010 - 11:14 PM) *
yea. i just changed new spark plugs, new spark plug wires, new coil, used ignitor, used fuel pump, rebuilt distributor. its getting spark and fuel. it cranks, but it just doesn't start. so, i have no clue of what it could be now. im absolutly out of ideas.
...5sFREAK...
post Sep 30, 2010 - 6:51 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yes, ignition coil
post Oct 1, 2010 - 1:29 PM
hokuten3
Joined May 30, '10
From PA
well, i changed the coil, and nothing happened. any other ideas?
...5sFREAK...
post Oct 1, 2010 - 1:38 PM
EKAn
Joined Apr 24, '07
From CA
QUOTE (hokuten3 @ Sep 30, 2010 - 6:18 PM) *
is it getting air? is there something clogging your intake?
what hes saying is if you put blue lights in you car youll lose hp.
post Oct 1, 2010 - 1:58 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If you have spark and fuel then you need to check your timing. You might have the distributor installed 180° off. You should also do a compression test.
**** Photobucket
post Oct 1, 2010 - 4:34 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Ok ok ok...
When you turn the key...what happens? Does the engine attempt to start or does it just not do anything?
When your starting the car do you smell gas like its running rich?
How many miles on this engine?
Is the check engine light on?
When it DID start and run, after it was warm did you still notice any problems?
Have you done anything recently before this problem started?
i would say also reset your ecu, unplug the battery completely (+ and -) and leave it for about 5 minutes. Come back and plug it in a try again. If it starts let it idle for about 5 minutes, then take it for a drive. This will reset your ecu to OEM standards as far as fuel/air mix..
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 29th, 2024 - 7:19 PM
