3 Pages V  < 1 2 3 >
> Engine problem, please HELP!!!, Engine only starts sometimes
post Oct 1, 2010 - 4:39 PM
i would say also reset your ecu, unplug the battery completely (+ and -) and leave it for about 5 minutes. Come back and plug it in a try again. If it starts let it idle for about 5 minutes, then take it for a drive. This will reset your ecu to OEM standards as far as fuel/air mix..
all you really need to do this is pull the EFI fuse in the engine bay fuse box for ~10 seconds.
that way, you dont loose your radio presets as well.
you need to check mechanical timing.
post Oct 1, 2010 - 9:42 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (EKAn @ Oct 1, 2010 - 1:38 PM) *
QUOTE (hokuten3 @ Sep 30, 2010 - 6:18 PM) *
its getting spark and fuel.
is it getting air? is there something clogging your intake?
no. nothings clogging the intake
QUOTE (95CelicaST @ Oct 1, 2010 - 1:58 PM) *
If you have spark and fuel then you need to check your timing. You might have the distributor installed 180° off. You should also do a compression test.
okay. i'll recheck the distributor timing. and my buddy just helped me doing a compression test. it was 170 for all for cylinder
...5sFREAK...
post Oct 1, 2010 - 9:49 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (SupraKid @ Oct 1, 2010 - 4:34 PM) *
Ok ok ok...
When you turn the key...what happens? Does the engine attempt to start or does it just not do anything?
When your starting the car do you smell gas like its running rich?
How many miles on this engine?
Is the check engine light on?
When it DID start and run, after it was warm did you still notice any problems?
Have you done anything recently before this problem started?
when i turn the key, yes, it attempts to start. it sounds like it wants to start running, but it never does.
and yes, when i start the car i could smell gas like its running rich.
my engine has 138,000 on it.
no, the check engine light isn't on.
when it did start and run, after the engine was warm, there weren't any problems starting the engine again. you could shut it off, and wait like 5-10 mins or so, and it'll start like nothing's wrong with it.
no, i bought the car like this. this is why the owner sold it. cause it wouldn't start most of the times.
...5sFREAK...
post Oct 2, 2010 - 11:38 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
yea... ok i helped him look at the car. he did a coil and a distributer along with new ignition wires and spark plugs. i did a dry compression test for him and got around 170 psi in all of the four of the cylinders. we also taped on the tank to check for a bad fuel filter and smelled that there was fuel coming to the engine. the car still does not run. i am think is it a timing belt issue... and for the "timing the distributer" idea, is that a necessary thing to do with a 6gc? lets here some input.
post Oct 3, 2010 - 11:22 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
when it doesnt start..
does it get fuel?
bridge B+ and FP in the diags box and listen for the fuel pump/fuel flow
crank it over about 15 times, pull a spark plug and see if it smells like fuel/is wet.
does it spark?
post Oct 3, 2010 - 2:43 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (stephen_lee @ Oct 3, 2010 - 11:22 AM) *
does it get fuel?
does it spark?
yea, when the engine doesn't start, its getting fuel, spark and air compression
...5sFREAK...
post Oct 3, 2010 - 8:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its missing one of them.
post Oct 4, 2010 - 2:57 PM
luka
Joined Jul 23, '08
From Hawaii
my 5s is doing almost the same thing, throwing a p1300 for ignition circuit malfunction #1. Just over 150k miles
Starts first thing in the morning when its still cold and runs fine, however, refuses to start in the PM after its hot.
replaced the distributor, timing belt, cap/rotor, plugs, wires all within a year.
Ignition coils are not avail anywhere (on island) and have to be flown in from state-side. Otherwise, I cleaned all the connectors and checked for bad wires and hoses.
plan to reset my ecu and shoot the timing today and see where that takes me.
post Oct 4, 2010 - 6:24 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
either wiring or coil.
post Oct 4, 2010 - 11:50 PM
luka
Joined Jul 23, '08
From Hawaii
pretty certain its the coil.
Timing was was pretty spot on, and after 20 min of failed starts, it finally started and ran normally.
post Oct 5, 2010 - 7:33 AM
hokuten3
Joined May 30, '10
From PA
yeah, i thought that it would have been the coil, but i changed it with a brand new one and it wasn't either.
...5sFREAK...
post Oct 5, 2010 - 1:02 PM
luka
Joined Jul 23, '08
From Hawaii
would you have another ECU to test?
post Oct 5, 2010 - 3:12 PM
DEATH
Joined Dec 19, '07
From tx
It could still be the ignitor coil wiring. I had the wiring burn up on me a few years back on my '99 GT
check the wires by feel - do they feel crispy and hard? Is the insulation cracking or looking burnt at all?
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Oct 6, 2010 - 10:05 PM
hokuten3
Joined May 30, '10
From PA
QUOTE (luka @ Oct 5, 2010 - 1:02 PM) *
yea, i have another same year celica. but its automatic. would that work?
...5sFREAK...
post Oct 6, 2010 - 10:07 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
it should
post Oct 7, 2010 - 4:50 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (hokuten3 @ Oct 6, 2010 - 10:05 PM) *
QUOTE (stephen_lee @ Oct 6, 2010 - 10:07 PM) *
it should
Yes - been there, done that. You just can't swap the oposite way [obviously]. Just be sure the pins are all in the same places - there were some differences over the years.
You'll get a code cause of the lack of auto tranny but it's easily cleared and you can defeat that code with some simple wiring.
EXT: WRC/TRD/404
post Oct 24, 2010 - 7:18 PM
luka
Joined Jul 23, '08
From Hawaii
After slaving a new coil, still have the same problem. i'll see about getting an igniter to slave in and unwrap the wires
post Jan 22, 2011 - 8:29 PM
luka
Joined Jul 23, '08
From Hawaii
after poking around and trying different things, found a little oil in the distributor so cleaned it out and replaced the cap/rotor after they looked worn.
changed the spark plugs and wires.
Had to replace the battery.
car ran fine after all of that for a little while and went back to p1300 no spark a day later.
Pulled the lead from the coil and found it only sparks once when I turn the key to <on> and no spark during cranking.
The wires look ok, but are pretty stiff.
Can't find a way to ohm the igniter itself, and getting to the crank sensor just to check if its dirty is beyond what i'm willing to try next.
All of the manuals I could find are more or less pointing to the distributor or ecu.
besides replacing those, i'm out of ideas...
post Jan 23, 2011 - 11:29 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
id try the dizzy
post Jan 24, 2011 - 12:45 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (stephen_lee @ Jan 23, 2011 - 11:29 PM) *
id try the dizzy
Replace the cold start sensor it is only $15 and causes the problems you describe. Mine was doing the exact same thing for a year before I solved it.
It is on the right next to the heater hose hookup, it is the right hand sensor next to temp gauge sensor.
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: November 29th, 2024 - 9:54 PM
