3 Pages V  < 1 2 3
> MOREFAST's 3SGTE Swap
post Oct 31, 2010 - 12:14 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
ah so THATS why no more clocked turbos! i noticed on prodigy's car first then a few other swaps. always forgot to ask ya.
post Dec 23, 2010 - 12:09 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE (Dr_Tweak @ Oct 30, 2010 - 12:41 PM) *
QUOTE (purplegt4 @ Oct 28, 2010 - 3:32 PM) *
QUOTE (Dr_Tweak @ Oct 28, 2010 - 3:18 PM) *
A/C lines took a bit of careful bending, but with a little creativity they did indeed work. Be sure to set aside several hours of labor for the work on the a/c lines, it's a bit of trial and error and you don't want to overdo it wink.gif
That's surprising.
I have the rhd connections from the 3sgte compressor. Don't know if they would hook up to my current AC lines.
Did you use any bending tools? or just bend (and hope it doesn't crease) method.
Sorry, I forgot one important part of that. You need to swap the "manifold" from the top of the 7A compressor over to the 3SGTE compressor, THEN the 7A lines will connect, with a little bending. We didn't have to use any tools for the bending work, you just need to go a little at a time and spread the bend over a longer distance so that they don't kink.
-Doc
Just tried to hook up the ac lines, they ended up rubbing against the berk downpipe.
post Dec 24, 2010 - 3:10 AM
Johnnyny
Joined Apr 28, '09
From York pa
morefast use the stock cat
post Dec 27, 2010 - 5:58 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
QUOTE (purplegt4 @ Dec 23, 2010 - 1:09 PM) *
That's surprising.
-Doc
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 27th, 2024 - 8:59 PM
