> Stuck wing, How to remove
post Sep 7, 2010 - 10:49 PM
dgbldr
Joined Sep 19, '08
From Michigan
Guys, I have a 3 post wing and I can't take it off. I removed the nuts and gave the studs a healthy whack with a drift punch. Nothing.
Any trick to getting it off?
Everything is stock and wing has never been removed before.
This post has been edited by dgbldr: Sep 7, 2010 - 10:49 PM
post Sep 7, 2010 - 10:52 PM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
QUOTE (dgbldr @ Sep 7, 2010 - 10:49 PM) *
when i was first taking mine off, i came across the same problem, it is glued on, and there is 2 clips holding it on, just give it a good yank and it should pop right off.
remember, there is 2 bolts on the left, 2 on the right, and one in the middle. there is one clip on the right side closest to the back, and the other on the right, closest to the back.
This post has been edited by Zake: Sep 7, 2010 - 10:54 PM
post Sep 8, 2010 - 12:53 AM
dgbldr
Joined Sep 19, '08
From Michigan
I did give it a good yank. I could see the trunk sheetmetal flexing. If I yank any harder the trunk lid sheetmetal is going to bend. I did remove the 5 nuts. Didn't see any clips.
Anyone try soaking it in WD40 or anything like that?
post Sep 8, 2010 - 1:32 AM
fishing line.
use it to cut the rubber. put it between the car and spoiler and work your way around the screws.
post Sep 10, 2010 - 6:25 PM
dgbldr
Joined Sep 19, '08
From Michigan
Thanks. That did it. Very thin fishing line, lots of heat from a hair dryer, took a long time. Then took another half hour to get the sealant off the lid and off the wing. That stuff is very sticky.
post Sep 12, 2010 - 1:41 PM
whatthe
Joined Aug 13, '08
From Australia
Video of this drift punch?!?
post Sep 12, 2010 - 2:34 PM
mak5603
Joined Oct 20, '08
QUOTE (whatthe @ Sep 12, 2010 - 1:41 PM) *
x2
2014 Toyota Rav4 XLE
post Sep 12, 2010 - 8:44 PM
dgbldr
Joined Sep 19, '08
From Michigan
Video? Do you mean you want to see what a drift punch is?
http://en.wikipedia.org/wiki/Punch_(tool)
Scroll down to "Drift"
post Sep 12, 2010 - 9:17 PM
ZGear
Joined Feb 16, '07
From BP, MN
QUOTE (dgbldr @ Sep 12, 2010 - 6:44 PM) *
LOL! WIN! I'm pretty sure everyone had a different idea. HAHAHAHAHA!
Lo-Fi Version Time is now: January 10th, 2025 - 7:38 PM
