Question on using an engine leveler for removal of Engine, how to use a leveler? |
Sep 10, 2010 - 2:20 PM |
Enthusiast Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
Hey guys, i just got my 97 back to my house and i'm ready to swap the engines, and i'm hoping i don't have near as hard as a time as i did pulling the 94's.. i was talking around to some of you on here and i heard the reason i was having such a hard time is because i didn't use a leveler. if someone could explain to me what a leveler does and how to use it, i would greatly appreciate it because i'm going to go out and pull the engine in the next hour so i can start the swap... thanks ahead of time guys!
This post has been edited by NOVAKx17: Sep 11, 2010 - 10:35 PM -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Sep 10, 2010 - 2:58 PM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
normally you have just a chain attached to the two hooks on your engine from the engine hoist...this allows the engine to be lifted straight up. or crooked but not varied depending on where you hooked your chain with the hoist
In most vehicles the engine needs to be tilted one way or the other as you are lifting or reinstalling it in order to clear certain components and such. A leveller applies a movable fulcrum to your chain point allowing you to make one end longer or shorter making the engine tilt like this note you thread the thru bolt at the top and it changes the fulcrum from one end to the other, different brands and styles exist but they all work on the same principle. This post has been edited by schmooot: Sep 10, 2010 - 3:01 PM -------------------- ST205 Crew represent
Challenge Accepted |
Sep 10, 2010 - 5:19 PM |
16 chain links on the drivers side hook, 4-5 on the passanger side.
use a jack to lower the drivers side down, and it comes right out. no need for the leveler. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 10, 2010 - 5:26 PM |
16 chain links on the drivers side hook, 4-5 on the passanger side. use a jack to lower the drivers side down, and it comes right out. no need for the leveler. hmmm interesting... and for reinstall, just reverse order i'm guessing? -------------------- NOVAKx17
Sep 11, 2010 - 6:06 AM |
16 chain links on the drivers side hook, 4-5 on the passanger side. use a jack to lower the drivers side down, and it comes right out. no need for the leveler. hmmm interesting... and for reinstall, just reverse order i'm guessing? yup. -------------------- Former Team 5SFTE pro member ;)
Sep 11, 2010 - 11:14 AM |
16 chain links on the drivers side hook, 4-5 on the passanger side. use a jack to lower the drivers side down, and it comes right out. no need for the leveler. hmmm interesting... and for reinstall, just reverse order i'm guessing? yup. thanks pressure. i'll be getting this done in the next couple days, if i have any problems i'll post back in here, but if all goes well i'll be posting up in my progress thread and you can close this one! thanks againn! -------------------- NOVAKx17
Sep 11, 2010 - 2:04 PM |
16 chain links on the drivers side hook, 4-5 on the passanger side. use a jack to lower the drivers side down, and it comes right out. no need for the leveler. hmmm interesting... and for reinstall, just reverse order i'm guessing? yup. thanks pressure. i'll be getting this done in the next couple days, if i have any problems i'll post back in here, but if all goes well i'll be posting up in my progress thread and you can close this one! thanks againn! no need to close it, its better to leave it open for future posters that are looking for the answer to the same question. one thing i would say, tho, is maybe try to be more discriptive in your titles, so that people who search the site get more chances to get hits on theyre questions. for instance, a good title for this thread might have been "question on using an engine leveler for removal" or somthing like that. good luck! -------------------- Former Team 5SFTE pro member ;)
Sep 11, 2010 - 5:20 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
I remember reading somewhere here saying it was easier to remove the 5sfe from the bottom is that true ??
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Sep 11, 2010 - 6:30 PM |
I remember reading somewhere here saying it was easier to remove the 5sfe from the bottom is that true ?? In an mr2, yes. But not in a celica IMO, unless it's AWD. -------------------- Former Team 5SFTE pro member ;)
Sep 11, 2010 - 8:27 PM |
Ok thanks for the clear up presure2.
Lo-Fi Version | Time is now: December 3rd, 2024 - 6:33 AM |
