> second time radiator fluid shoots out., head gasket.?
post Sep 11, 2010 - 9:43 PM
Candiiman
Joined Mar 10, '09
From pembroke pines FL
ok so like 4 months ago my 7a over heated and the radiator fluid shot out .. idk from where... then it didnt crank.... next day filled it up with anti freeze, and cranked right up. 4 days ago same thing happen. could it be the head gasket? the head? any help will be greatly appreciated
post Sep 11, 2010 - 11:23 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
oh yea, 100% sure that fluid coming from somewhere is a head gasket!!!
or you could tell us where the fluid is coming from and then fix that.
post Sep 12, 2010 - 7:44 PM
Candiiman
Joined Mar 10, '09
i cant tell where it shoots out from. but im gunna drive it tomorrow see what happens...
post Sep 12, 2010 - 8:38 PM
ZGear
Joined Feb 16, '07
From BP, MN
Is there any coolant residue in the engine bay anywhere? Wet spots, or puddles of coolant? You may be leaking from a hose, but that shouldn't deplete your whole coolant supply, unless it's a lower hose. Other than that, it's very well a head/gasket issue.
post Sep 14, 2010 - 7:25 AM
Bitter
Joined Mar 11, '06
check behind the head, just use your eyes and LOOK!! get a flashlight, get a friend, get a mirror and LOOK. if you don't know where its coming from or whats happening then how can we help you?
at this point, the best solution may be for you to just buy a brand new car with a nice long warranty and suffer payments. atleast that way you don't need to do anything other than change oil and put in gas.
post Sep 19, 2010 - 8:15 AM
KALLusion
Joined Nov 7, '09
From Owen Sound
This may sound really simple zbut check your rad cap, I had a civic that all the coolant vanished from, and it turned out that the rubber ring had crumbled away over time, I changed the cap, no more problems.
" Trailers are for camping. Cars are for driving & it does not matter how much money you have if you ain't enjoying it. "
post Oct 3, 2010 - 12:56 AM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
well heres the bad new guy.. if u ignored ur temp gauge and it over heated to the point it shot coolant from somewhere i am 99% sure u now have a warped head take it to a shop because u can not just replace head gasket and be done ur engine will need to be decked and checked for cracks..
Lo-Fi Version Time is now: November 29th, 2024 - 3:16 AM
