ST205 Powered COUPE!!! |
Oct 25, 2011 - 6:42 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
so i took the knuckle off the celi yesterday and dropped it off down the road to get the new wheel bearing pressed into the hub and this is what i found..
it seems like the bearing was grinding away at the shaft on the hub and now the outter race sits lose instead of being tight like it should. has anyone else had this happen to them before? im going to order a new hub from toyota tomorrow unless anyone else sees another solution to this lol.. if its not one thing its another.. just read my sig once this is fixed im more then likely going to take it off the road and start saving up for the rest of the suspension maintence, which is why i just bought this tonight.. my new winter beater since my brother is going to take the neon for his first car, its a 96 ranger -------------------- st205 powered ss3 coupe
Oct 26, 2011 - 1:23 AM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
Happens from driving too long on a bad bearing.. I've been there twice..
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Oct 26, 2011 - 4:47 PM |
Happens from driving too long on a bad bearing.. I've been there twice.. thats what i figured, its the first time ive had to replace the bearing so i wasnt 100% sure. im pickin up a new hub tomorrow from toyota and going to get the bearing pressed in and put it back together at the house. -------------------- st205 powered ss3 coupe
Nov 5, 2011 - 12:01 AM |
Cars running good right now, no problems with the new hub and bearing. drivin the 3s during my first fall season is alot of fun, with that big IC suckin in all that cold air the thing comes to live quitr nicely to say the least
i got a sticker for it today before i put it away for the winter, probably going to put the truck on the road sometime next week or so. i put to much time into this car that i dont wanna meet a snow bank even tho i kno the car can handle it. excited about the truck tho also took my gauge cluster for the first time today to pull out the abs bulb so i can pass my inspection ha. while i was in there i took the clear plastic cover off and cleaned it up a bit, came out pretty good. -------------------- st205 powered ss3 coupe
Nov 7, 2011 - 10:57 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
also took my gauge cluster for the first time today to pull out the abs bulb so i can pass my inspection ha. while i was in there i took the clear plastic cover off and cleaned it up a bit, came out pretty good. http://www.6gc.net/forums/index.php?showto...0347&hl=srs |
Nov 24, 2011 - 1:29 AM |
havent updated in a while, been really busy with school and work havent had anytime to play with the car. car is off the road tho and in the garage for the winter.
im in the process of clearing out a space at my grandfathers barn to store it there since my dad is working out of the garage. few weeks back i picked a parts car, 96 st limited edition. i bought the limited edition seats (only passenger and rears, someone took the drivers one already) the black carpet (mines tan) 2 post hatch spoiler, headlights, and a hood and gunna play around with the celi this winter and change it up a bit. ive been thinkin about just buying a single racing seat for the drivers side to offset the missing drivers seat to the set. if anyone has a limited edition seat they wanna part way let me kno! ill post pics later, have a happy thanksgiving guys! -------------------- st205 powered ss3 coupe
Jan 17, 2012 - 11:37 PM |
some new pics, been workin on the celi here and there between work
new seats relocated my cutout switch modded the crash bar for better airflow.. more pics later got my DO 2 quart tank in the mail also recieved my poly sway bar bushings and st185 front endlinks going to get spacers made up soon for my spherical shifter bearings This post has been edited by Ted95: Jan 17, 2012 - 11:38 PM -------------------- st205 powered ss3 coupe
Jan 18, 2012 - 11:38 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Let us know how you like the water injection man! I'm contemplating running this myself. I also want to copy your intercooler piping! I love it!
Jan 19, 2012 - 12:06 AM |
Let us know how you like the water injection man! I'm contemplating running this myself. I also want to copy your intercooler piping! I love it! Thanks man, Manny did my piping for me, its a good route and flows well, no real sharp angles just smooth bends. i might have it re-done with better quality piping. the Devils Own has had good reports in the past with these motors, but ill post up my results when its going. This post has been edited by Ted95: Jan 19, 2012 - 12:06 AM -------------------- st205 powered ss3 coupe
Mar 12, 2012 - 9:55 PM |
been doing some work to the celi the past few days, want to get her on the road soon but theres work to be done!
first, my version of the Toms style cluster installed with the new 7th gen steering wheel started the Devils Own install, ran the lines from the trunk to the bay, the lines fit perfect in the pastic peice under the carpet also mounted the tank in the trunk and made a bracket to go with it i also installed a apexi turbo timer that i picked up cheap, plug and play.. more to come -------------------- st205 powered ss3 coupe
Mar 13, 2012 - 1:05 PM |
DO WANT!
Mar 13, 2012 - 2:06 PM |
If you need a hand with any of the wiring, I'm right around the corner haha
Mar 13, 2012 - 11:06 PM |
I cant wait to have this thing hooked up when i get her on the road. i picked the kit up off a member a a few summers ago and came with the adjustable pressure switch that i want to replace with the digital progressive adjustable controller. cars going to be fun with the meth kit lol.
i should have some pics up tomorrow of another project ive been workin on to go in the celi -------------------- st205 powered ss3 coupe
Mar 14, 2012 - 9:28 PM |
trunks done for now, i wont be wiring up the pump until i order the new controller for it.
next is cleaning up the seats and carpet, wait til you guys see how they come out hehe -------------------- st205 powered ss3 coupe
Mar 18, 2012 - 10:12 PM |
Alright so i finished my interior during this spring break like i wanted to today, came out great!
saturday i took out the tan head liner and painted it gray to help go with my refirbished Limited Edition seats that i painted with an interior paint. Gray headliner flash makes the liner look lighter then what it is, it looks darker in person black rug before paint rug painted and installed cant find the before pics of the seats but this gives an idea how faded they were seats after what was left of the old setup lol i started to tear it down months ago gutted rug installed rear seats passenger done im more then happy with the way this interior came out, it looks 10x better in person because the seats really pop after repainting the black trim after a good wash. the rug and headliner change the whole feel of the car from a drivers stand point, as well as the 7th gen wheel and jdm style cluster, i cant wait to driver her daily again! -------------------- st205 powered ss3 coupe
Mar 18, 2012 - 11:43 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
beautiful work! everything looks great. I love those seats.
mine's limited edition but I didn't get the seats. -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Apr 6, 2012 - 4:57 PM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
she's coming along nicely, Cam!
-------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Apr 6, 2012 - 11:21 PM |
she's coming along nicely, Cam! thanks Alex, hoping to have it repainted and ont the road by the end of the month. time will tell. -------------------- st205 powered ss3 coupe
Apr 9, 2012 - 8:35 PM |
front and rear pads and rotors came in today, as well as my new inner and outter tie rods.
Apr 14, 2012 - 5:41 PM |
update, installed my front poly sway bar bushings today and st185 endlinks, torque steer reduced dramatically. very pleased!
This post has been edited by Ted95: Apr 15, 2012 - 3:44 PM -------------------- st205 powered ss3 coupe
Lo-Fi Version | Time is now: November 26th, 2024 - 6:26 AM |
