Blown midpipe gasket, can i use high temp silicone? |
Sep 14, 2010 - 1:58 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
So the other day my car starts to sound like there is a slight vibration in the midpipe, that slight vibration turns out to be a blown out exhaust gasket between the midpipe and the header, did i mention no stores around here carry gaskets for the aftermarket header? so my question is, can i use high temp silicone to fix this? says its good to 650 degrees so can i use this to replace the blown out one?
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Sep 14, 2010 - 3:23 PM |
Enthusiast Joined Oct 24, '09 From Appleton, Wisconsin 54915 Currently Offline Reputation: 7 (100%) |
So the other day my car starts to sound like there is a slight vibration in the midpipe, that slight vibration turns out to be a blown out exhaust gasket between the midpipe and the header, did i mention no stores around here carry gaskets for the aftermarket header? so my question is, can i use high temp silicone to fix this? says its good to 650 degrees so can i use this to replace the blown out one? You can use that for a temp fix but if you can't find a gasket i would suggest using Permatex muffler and tailpipe sealer. You should be able to find it at any local auto store. I use without a gasket and i haven't had a leak yet. Although it is a little messy, and sometimes difficult to clean. It gets the job done and is supposed to be resistant up to 2000 deg. Good luck! |
Sep 17, 2010 - 9:09 AM |
Wow this worked for about a day....
Sep 17, 2010 - 11:14 AM |
those gaskets should be available in you local stores by mail order...
Sep 17, 2010 - 4:19 PM |
Finally found the gasket today, well similar had to modify it a little but it works now, found it at an exhaust shop
Lo-Fi Version | Time is now: December 4th, 2024 - 5:11 AM |
