about to swap a 4th gen in? lookie here, here's some useful info |
Nov 29, 2010 - 10:09 PM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
must have been a complete nutz....but what mods are needed for the axles east? can you explain if any is needed to mod or are the axles off st215 perfect fit? or are there any interchangeable axles among the toyota family for the tranny...well i guess it all depends on the tranny. what would you recommend?
Nov 30, 2010 - 12:42 AM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
must have been a complete nutz....but what mods are needed for the axles east? can you explain if any is needed to mod or are the axles off st215 perfect fit? or are there any interchangeable axles among the toyota family for the tranny...well i guess it all depends on the tranny. what would you recommend? lol its ok bro, no changes are necessary for the st215 swap. that motor is bascially the same as the other gens. other minor differences will need modification (ex: cams) but axles can be used from a GT celica and the trans from a V6 solara,Turbo MR2 or the most common, a camry (s54) i have some pics (i think?) of the axles going in, they are the same will go in without any more trouble than normal. i serioiusly doubt the axles from a caldina will fit (because is an all wheel drive car) -------------------- |
Nov 30, 2010 - 7:15 AM |
to clarify, i would still need differ inners depending on the tranny whether it's a mr2, solara, camry, or my reg gt tranny...and the outer would be what exactly?
Nov 30, 2010 - 8:18 AM |
to clarify, i would still need differ inners depending on the tranny whether it's a mr2, solara, camry, or my reg gt tranny...and the outer would be what exactly? you ONLY need the mr2 inners, and alltrac outters if your using the E153. the S54 uses the stock axles. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 21, 2011 - 3:27 PM |
as far as the parts are concerned, i neglected to be specific (thanx chacha )
as reccommended change the parts mentioned before, but to make it easier, here are the part numbers of the things that will fit on the 4 gen, when refreshing your motor i dont have the part numbers of the rear main seal ($26.26) and front (crank) main seal ($10.00) off hand but they ARE the same as the other gens, and can be found in the parts thread made by our good buddy lagos! (remember to call coniceli toyota and have part numbers, not a clusterfcuk like i gave lagos lolz) Cam seal-903111-35022-14.90 timing belt-13568-79045 $26.49 BE CAREFUL.... this timing belt is likely from a 2nd gen (usdm) will be off by 1 tooth thermostat-- apparently the 4th gen thermostat is slightly larger so tweak informed me that one can use a thermostat from a 4 runner 98-2000s iirc. H20 pump-16100-79127 (GEN II) 16100-79127-$102 H20 pump (Gen III) 16100-79126 NOTE: These two parts are off by one number, but i believe they are the same all of your accessory (aka V belts) are the same as the other gens. Idler pulleys 13505-88383-$88.42 13503-63011-$41.69 sorry if this is a bit thrown together, i just wanted to get the info out there before i went to work, any questions shoot! EDIT: from what i understand the head gaskets are the same as well. im 99.9% certain of it This post has been edited by easternpiro1: Feb 24, 2011 - 5:05 PM -------------------- |
Aug 10, 2011 - 5:23 AM |
found some extra info for anybody curious about the 4th gen....
study to show thyself approved! http://www.alltrac.net/phpBB2/viewtopic.ph...71&start=30 -------------------- |
Nov 13, 2011 - 1:01 PM |
Thought i would update this thread, i totally forgot to add information about the RODS of the 4th gen engine. the rods in the 4th gen are DEFINATELY THE WEAK POINT OF THIS ENGINE. In my attempt to correct this problem, i got some REALLY good info about 4thgen versus 3rd gen rods
thanks guys! read up! http://www.6gc.net/forums/index.php?showtopic=80474&hl= -------------------- |
Nov 14, 2011 - 12:31 AM |
Enthusiast Joined Feb 28, '08 From Miramar, Florida Currently Offline Reputation: 16 (100%) |
Does anyone have a Caldina (ST215) BGB? I cant find one anywhere...
Nov 14, 2011 - 9:35 AM |
im sorry, whats BGB stand for?
Nov 14, 2011 - 11:23 AM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Big Green Book. He wants the repair manual.
This post has been edited by bsamps4: Nov 14, 2011 - 11:26 AM -------------------- |
Nov 14, 2011 - 2:15 PM |
Oh! Ask cuts or someone in australia. Maybe even 3way stunna. Hes in japan... But idk if it will be in english! I have some big ass parts list for the caldina but idk where it is on my comp
Nov 16, 2011 - 6:07 AM |
Enthusiast Joined Nov 18, '10 From montreal Currently Offline Reputation: 0 (0%) |
to clarify, i would still need differ inners depending on the tranny whether it's a mr2, solara, camry, or my reg gt tranny...and the outer would be what exactly? you ONLY need the mr2 inners, and alltrac outters if your using the E153. the S54 uses the stock axles. it need to be the st185 outter , not the st205, they wont clip[ |
Dec 21, 2011 - 9:11 AM |
Enthusiast Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) |
to clarify, i would still need differ inners depending on the tranny whether it's a mr2, solara, camry, or my reg gt tranny...and the outer would be what exactly? you ONLY need the mr2 inners, and alltrac outters if your using the E153. the S54 uses the stock axles. it need to be the st185 outter , not the st205, they wont clip[ We actually used ST165 outters, and they work as well. -------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
Jan 22, 2012 - 12:57 AM |
Enthusiast Joined Mar 1, '10 From TX Currently Offline Reputation: 16 (90%) |
lol its ok bro, no changes are necessary for the st215 swap. that motor is bascially the same as the other gens. other minor differences will need modification (ex: cams) but axles can be used from a GT celica and the trans from a V6 solara,Turbo MR2 or the most common, a camry (s54) i have some pics (i think?) of the axles going in, they are the same will go in without any more trouble than normal. i serioiusly doubt the axles from a caldina will fit (because is an all wheel drive car) was also intrested in this swap can you elaborate on the minor differences(ex: cams) that needed modifications for your swap? peace -jec -------------------- JN 3:16
Jan 22, 2012 - 5:43 PM |
lol its ok bro, no changes are necessary for the st215 swap. that motor is bascially the same as the other gens. other minor differences will need modification (ex: cams) but axles can be used from a GT celica and the trans from a V6 solara,Turbo MR2 or the most common, a camry (s54) i have some pics (i think?) of the axles going in, they are the same will go in without any more trouble than normal. i serioiusly doubt the axles from a caldina will fit (because is an all wheel drive car) was also intrested in this swap can you elaborate on the minor differences(ex: cams) that needed modifications for your swap? peace -jec hey bro, the differences are minor, the cams on a fourth gen have a notch on the end where it fits into a slot for somthing... i cant remember at the time.... also the rods are from a beams motor and are skinnier than the other generations. he motor is a high compression which means quick spool, but be careful with boost. not much needs to be modified to be honest with you if youre doing a basic swap. its just about the same as other gens in this aspect. it has no spark plug wires, and puts out a bit more hp than the 3rd gen, and is a newer motor, but to be honest, if you want high horsepower get a 3rd gen -------------------- |
Jan 23, 2012 - 2:15 PM |
thanks for the info. yeah seems the 4th gen is a little better option for me as i'm looking for an alternate replacement option rather than a platform to mod. and they can be sources much more cheaply
Lo-Fi Version | Time is now: November 26th, 2024 - 2:43 PM |
