Help!!! Front end issues |
Sep 15, 2010 - 9:18 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
Ive had my coilovers on for about a month now, no issues, its been aligned and all that, last night while driving home i hit a small pothole that couldnt be avoided, a few minutes later i noticed that my steering wheel is to the left and im going straight, still confused, get off the exit and now every time i turn somewhat hard the tires sequel, someone help?
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Sep 15, 2010 - 10:12 AM |
do a visual inspection and look for bent / broken suspension parts. sometimes it can'e be spotted as easy, but ytour car will definately need to be re alighned at the very least, that's if you are lucky, if you are like me, you'll need a new control arm ( been there already )
Sep 15, 2010 - 12:09 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Suuuucks When I was in my accident, My alignment got SCREWED due to obviously, taking the blunt hit in the LH wheel area, and a bent strut That was an 18 wheeler wheel, you hit a pothole. I don't think it'll be that bad, but good luck
June '12 COTM '95 AT200 |
Sep 15, 2010 - 12:16 PM |
Enthusiast Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
Jack up the car take off the wheel. Check if everything is tightand secure. If any arms are bent. Check if the wheel itself is cracked or bent. Get an alignment too. But if theres noise somethings ****ed.
This post has been edited by whatthe: Sep 15, 2010 - 12:17 PM -------------------- |
Sep 15, 2010 - 12:32 PM |
Finally got home from school today, the alignment is not too far off its just the steering wheel thats bugging the crap out of me, popped the hood when i got home and looked at the wheel, no cracks or anything like that, but my camber is WAY negative, so im gonna fix that and hopefully get a friend to do the alignment tomorrow
Sep 15, 2010 - 12:36 PM |
You need to pop the hood to inspect your rim o.O What kind of celica do you have ?!?
Sep 15, 2010 - 3:04 PM |
no popped the hood to check out the camber plate lol
Sep 15, 2010 - 3:06 PM |
You need to pop the hood to inspect your rim o.O What kind of celica do you have ?!? LOL! -------------------- taking too long to mod since '09
Sep 16, 2010 - 7:17 AM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
Only way to tell is when its on the alignment machine, they will tell you if it doesn't line up straight and IF it doesn't its most likely a control arm or strut, Mine were bent after someone drove into me and you couldn't tell just by looking.
Sep 16, 2010 - 8:37 AM |
fixed the problem with the alignment, when i hit the pothole it MOVED my camber plate all the way to negative, fixed that and all is now well
Sep 16, 2010 - 10:02 AM |
fixed the problem with the alignment, when i hit the pothole it MOVED my camber plate all the way to negative, fixed that and all is now well Damn! I must have completely over-powered those teeny bolts holding it in place, huh? Glad it's fixed -------------------- taking too long to mod since '09
Sep 17, 2010 - 9:09 AM |
i smacked the hell out of that pothole
Lo-Fi Version | Time is now: January 11th, 2025 - 6:43 PM |
