7AFE Fluid Data Specs., Based on a 1995 but should apply to other years |
Sep 18, 2010 - 6:44 PM |
Enthusiast Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
Hey Guys! Here is the promised 7AFE chart. Thanks!
7AFE Fluid Data Specs. Application - Fluid Type : Capacity = Litres (U.S. quart , imperial quart) A/C Refrigerant. - R134a : 650 +/- 50g (22.93 +/- 1.74oz) Air Condition Oil - ND-Oil 8 or equivalent Brakes - SAE J1703 DOT 3 Clutch. - SAE J1703 DOT 3 Differential Oil (manual Transmission) - ATF Dexron II or III : 1.6L (1.7, 1.4) Engine Oil (Dry Fill)........................................ - SH "E-C II" : 4.3L (4.5, 3.8) Engine Oil w/filter change (Drain & Refill) .. - SH "E-C II" : 3.7L (3.9, 3.3) Engine Oil w/o filter change (Drain & Refill) - SH "E-C II" : 3.5L (3.7, 3.1) Engine Cooling System (Manual).... - Ethylene glycol base (no alcohol) : 6.1L (6.4, 5.4) Engine Cooling System (automatic) - Ethylene glycol base (no alcohol) : 6.6L (7.0, 5.8) Fuel Tank - Unleaded OR87 (RON91) or Higher : 60L (15.9 gallons, 13.2 imperial gallons) Power Steering - ATF Dextron II or III : 0.8L (0.85, 0.70) Automatic Transmission A246E Dry................ - ATF Dextron II or III : 7.6L (8.0, 6.7) Drain & Refill - ATF Dextron II or III : 3.1L (3.3, 2.7) Manual Transmission S54 - API GL-3, GL-4 or GL-5 SAE 75W-90 : 2.6L (2.7, 2.3) -------------------- |
Sep 19, 2010 - 8:46 PM |
Enthusiast Joined Nov 14, '09 From Saskatoon Currently Offline Reputation: 0 (0%) |
Niiiceee man, thanks a lot! x10
Sep 19, 2010 - 8:48 PM |
Wow that's great. Awesome! Thanks.
'93 MX-5 LE |
Sep 22, 2010 - 6:11 PM |
*like*
Lo-Fi Version | Time is now: January 10th, 2025 - 12:21 AM |
