Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) ![]() |
**** Problem Solved ***** JDM head has different size injector seals. (had to use some from a USDM 2jz -go figure-)
Thanks for the help of all those who responded. The car will run w/my foot on the gas some. the good: vacuum lines are tight or capped off (no known leaks) timing is set perfect, including dizzy new wires/plugs will boost and seems to run fine w/foot on the gas and RPM's above 2k (fuel pump is on, fpr and injectors should be working...) mechanically sound (bottom end & head) current AFM hasn't been adjusted (adjustment screw is still capped) throttle body has been pretty thoroughly cleaned (idle set screw is set the same as 3 other throttle bodies I've got sitting around brand new battery harness was made by Tweak'd Tunning (previously Phoenix, Josh in particular?) swapped out turbo's too, newly flushed coolant & oil, all coolant lines are tight. unknown: AFM could be causing issues but I've got two of them and switching them out doesn't seem to change anything IAC may or may not be working, but I've switched it out w/the others I've switched out ECU's (matching year and such) There are a couple local shops that know jack about Toyotas or this swap in particular. I know I'd end up taking it there and $2k later they still wouldn't know whats causing the problems or how to fix it. Any help would be greatly appreciated (especially local) as this swap is going on a year and a half. Thanks in advance. This post has been edited by cjh4l22: Sep 29, 2011 - 1:21 PM -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
check the sensors on the coolant neck?
do symtoms change as the car warms? -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
did you uninstall the throttle position sensor ?
Check the piping between the afm and the turbo for any loose connections or air leaks.
Check BOV for air leaks. This post has been edited by lagos: Sep 22, 2010 - 10:48 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
Idle air control valve?
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) ![]() |
^^^What he said!
check the sensors on the coolant neck? do symtoms change as the car warms? all sensors on the coolant neck are connected and seem to be working fine did you uninstall the throttle position sensor ? i have not thought of that... might be my next step for sure. Check the piping between the afm and the turbo for any loose connections or air leaks. Check BOV for air leaks. i'm pretty sure all piping is hooked up properly (followed vac diagram) and held tight w/worm driven clamps. Idle air control valve? ya know... i'm starting to get the feeling that it might be. even thought i've switched out (another throttle body). -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
if you haven't uninstall it, don't remove it, but if oyu did, make sure is set correctly, is a pain to get right
if you haven't uninstall it, don't remove it, but if oyu did, make sure is set correctly, is a pain to get right i pulled the connector from it completely earlier and it wouldn't really run at all. died pretty much instantly. so it is functioning, just might need adjustments. need to check IAC and AFM the same way and see if they act similarly. sound like a plan anyone? -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
you still haven't answer the first question
DID YOU REMOVE THE TPS SENSOR at any point ? not the plug but if you actually removed the sensor from its location -------------------- ![]() |
you still haven't answer the first question DID YOU REMOVE THE TPS SENSOR at any point ? not the plug but if you actually removed the sensor from its location no i haven't removed the tps sensor. no need to yell lol. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
Enthusiast ![]() ![]() ![]() Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) ![]() |
Uses either a scope or test light on all sensers mentioned above to make sure they are getting power and sending a signal to the pcm. If your getting power to it and no pulse to the pcm, its a bad senser, or if your not getting power to it check the ground if the senser has 3 wires and ohm the wire to make sure it is still good.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) ![]() |
do u have a check engine light on?
Uses either a scope or test light on all sensers mentioned above to make sure they are getting power and sending a signal to the pcm. If your getting power to it and no pulse to the pcm, its a bad senser, or if your not getting power to it check the ground if the senser has 3 wires and ohm the wire to make sure it is still good. this is one of my next steps. do u have a check engine light on? nope -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) ![]() |
I feel for you dude - the only thing I can say is stick with it. Once you get it running right it will make all this seem like a necessary step.
Good luck ![]() -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Yea I am getting a little frustrated though and getting to the point where I'm willing to send it to a shop. If Tweak'd wasn't in Georgia (14hours from me) then I'd take it there...
![]() Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) ![]() |
If the shops around your area don't know jack about the swap don't waste your time and money, just stick with it, when everything is all figured out you will be happy you did
![]() -------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) ![]() |
I don't get the problem. Are you saying the car doesn't hold idle by itself?
-------------------- "God created turbo lag to give V8's a chance"
I don't get the problem. Are you saying the car doesn't hold idle by itself? yea... -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
Lo-Fi Version | Time is now: February 26th, 2025 - 1:42 PM |
