> How to unable the DRL?
post Sep 24, 2010 - 12:08 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
I was wondering..
How could I stop the DRL from lighting? I think it kills the look when they're on and pretty useless.
Exept from letting the hand brake up of one notch, is there any other solution like cutting a wire or what ever? Thanks!
This post has been edited by dudeofchaos: Sep 24, 2010 - 7:42 PM
post Sep 24, 2010 - 12:17 AM
block
Joined Jul 27, '06
From Soda
6gc celicas never came with drl. 7th gen celicas did. When I had my 2000 celica gts, I had to cut a wire. My is300, there was a plug.
post Sep 24, 2010 - 12:33 AM
vile_v
Joined Jun 16, '07
From Vancouver, Canada
DRL's only came on Canadian spec model.
Its mandatory to have them, and its also illegal to drive without them. Well that's how the rules are in BC anyway.
But yeah usually its just another wire connected to the high beam headlight. Cut that it well stop working.
This post has been edited by vile_v: Sep 24, 2010 - 12:33 AM
post Sep 24, 2010 - 11:51 AM
demonofsteel
Joined Aug 18, '10
You should not remove your DRLs at any time for any car in Quebec. They are mandatory according to the CSR (Code de la Sécurité Routière) and you can get a ticket for having a car without DRLs (not sure, but I think it's a 154$ fine).
Even myself who has an imported GT4, I needed to install DRLs to be legal. They're not required at inspection and I see many cars with disabled DRLs, but I prefer the legal way, I don't want to end up getting a ticket just because of some DRLs.
Depending of the equipment on your car, you could switch your DRLs to your fog lights for example, it's all wiring things up, which is not hard at all.
post Sep 24, 2010 - 11:59 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
before you start your car, click your e brake up once and when you go to put it in gear the headlights should not come on.
My buddy in a hond taught me that haha.
My Celica!
post Sep 24, 2010 - 1:05 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (vile_v @ Sep 24, 2010 - 1:33 AM) *
Yeah I know. Mine is a GTS (canadian model only) so that's why I have DRL on it.
I know it's not legal but I don't really care haha.
QUOTE (demonofsteel @ Sep 24, 2010 - 12:51 PM) *
I know it's mandatory, but I seriously don't care much.
Do you think it would be possible to change de DRL from the high beams to the low beams?
QUOTE (jordisonjr @ Sep 24, 2010 - 12:59 PM) *
Yeah that's what I do actually. But I wanted to find another way to disable them.
This post has been edited by dudeofchaos: Sep 24, 2010 - 1:04 PM
post Sep 24, 2010 - 1:12 PM
block
Joined Jul 27, '06
From Soda
sorry for my ignorance kindasad.gif didn't know canadian celicas came with drl smile.gif
post Sep 24, 2010 - 7:43 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (block @ Sep 24, 2010 - 1:12 PM) *
Too bad, it's gotta be one of the only model with the DRL, Fml hahaha Atleast it prooves it's canadian smile.gif
This post has been edited by dudeofchaos: Sep 24, 2010 - 7:44 PM
post Sep 24, 2010 - 9:22 PM
block
Joined Jul 27, '06
From Soda
yeah i learned something new today.
post Sep 27, 2010 - 12:24 PM
demonofsteel
Joined Aug 18, '10
You could switch your DRL from high beams to low beams pretty easily as well. There would be 2 options that I would know how to do...
1) I don't know how the DRL circuit is done on Celicas, but here is what you could do... Delete the DRLs and wire the low beams to turn on when you turn your key to the on position. Costs very little, but you're stuck with DRLs that are as bright as the real low beams (which I don't think looks too good).
2) Buy some JDM headlights (either projectors or regular ones) and you have a nice socket for a 194 bulb in the low beam. Just put a LED 194 bulb in that socket and you have very nice looking DRLs (even a regular 194 bulb works and looks better than DRLs in high beams, but LED bulbs looks very nice).
post Sep 28, 2010 - 9:06 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (demonofsteel @ Sep 27, 2010 - 12:24 PM) *
Oh, I didn't know about number 2! Thanks a lot! I was actually planning to buy Jdm low beams projectors and clear high beams. So I sure will do this! Will there be any wiring cutting/connections to do to switch the DRL to the Low beams' 194 bulb?
Sorry, I'm not too good with electrical parts haha. I guess I'll have to cut the wires from the High beams' DRL at least?
This post has been edited by dudeofchaos: Sep 28, 2010 - 9:07 AM
post Sep 28, 2010 - 11:54 AM
demonofsteel
Joined Aug 18, '10
Of cource you will need to run a wire for that 194 bulb in the low beams and you'll need to cut your current DRL as you guessed.
In my opinion, that is what looks the best. It looks nice, it's not anoying and it's legal.
post Sep 28, 2010 - 12:08 PM
Rusty
Joined Nov 5, '07
From New Zealand
what are DRL??
post Sep 28, 2010 - 5:20 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (demonofsteel @ Sep 28, 2010 - 11:54 AM) *
Yeah, I've seen it once, and it definatly looks way better! It's not the DRL itself that I dislike, it's the high beams.. I think it doesn't look good when they're on (with the low beams off). So I guess I will go with this option! Thanks a lot for the information!
QUOTE (Rusty @ Sep 28, 2010 - 12:08 PM) *
what are DRL??
DRL = Day Running Lights/Lamp
This post has been edited by dudeofchaos: Sep 28, 2010 - 5:20 PM
post Sep 28, 2010 - 8:23 PM
demonofsteel
Joined Aug 18, '10
Glad I could help. If you need help for wiring things up when you're ready, send me a pm and I'll try to guide you through it.
post Sep 29, 2010 - 2:50 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (demonofsteel @ Sep 28, 2010 - 8:23 PM) *
Alright, thanks again! I'm not planning to have them soon because I've got some things to do before going in the exterior styling but I sure will get them as soon as possible1
Lo-Fi Version Time is now: November 27th, 2024 - 12:20 AM
