Brakes "creek" when pushed down (slow or stopped), read, wondering if anyone knows, little hard to explain |
Sep 24, 2010 - 12:54 AM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
So i recently noticed this odd noise my "brakes" make (imagine it is the brake since it only happens when they are depressed )
It is only when I am parked (starting my car I press it in to take off the ebrake and can hear it) or like rolling to a stop sign at 5mph (or at least this is when i can hear it). When the pedal is depressed, it goes down a slight bit, and then starts to feel harder as i push further. After the initial push when it gets hard, if i push slightly past that (only when im coming to a complete stop, or taking the ebrake off. I never push the brake further any other time) The front brakes kind of creek (sounds like it comes from the front). I can only explain it as like an eerie sound of a creeky door Braking is not any different since it started (at least nothing major) I was wondering if this is a sign of the caliper going? I replaced the pads and rotors when i got the car, but not the calipers, and I imagine the condition everything else on my car was, that they are pretty old. Its an odd sound, hard to explain, maybe ill get a video -------------------- |
Sep 24, 2010 - 12:59 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I got my brakes all around replaced (front rotors/pads, rear drums/shoes) not even 150 mi ago and they still do it sometimes. I don't think it's anything. I mean, new brakes, c'mon. Haha
June '12 COTM '95 AT200 |
Sep 24, 2010 - 11:14 AM |
Enthusiast Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
it is the little shims that hold your pads in place, they are usually rusted a bit and naturally rubb up against the caliper making that noise, if u have a brake job done they should use a bit of siliglide so that the shims can slide with out creekin like they do. i did mine yesterday and all that noise went away. or it couls be a frozen slider pin in the caliper, i had one on mine, so i took a acetylene torch to it and wiggled it out and lubed it up, this prevents your brakes from possibly dragin and making that noise.
This post has been edited by 4-eyed-freek: Sep 24, 2010 - 11:17 AM -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Lo-Fi Version | Time is now: January 11th, 2025 - 2:06 AM |
