> fog light wiring
post Sep 25, 2010 - 1:27 AM
AdrianF
Joined Mar 14, '10
From colorado
i recently bought some fog lights for my 94 gt and i have no clue how to install them, they need a 12 v source, where do i hook them up?
(\__/)
post Sep 25, 2010 - 9:27 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (AdrianF @ Sep 25, 2010 - 2:27 AM) *
You have to run the positive wire to the inside and put a switch somewhere on your dash, then run the other wire from the switch to the battery's positive terminal.
Run the ground wire from the lights to the ground terminal on the battery.
post Sep 25, 2010 - 10:41 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
There are a ton of threads covering this topic. I know cause I went through the same thing (mostly cause 94-95 dont have the hook up for fogs). The best way to do it is to wire it to a separate switch (like here, scroll down you'll see the pic). What I did was tap into the 12v power source for my side markers, and wired a separate ground. But if you use the search feature you will find several different options on how to do this.
Cause your other one got closed down, I was wondering why there were two of the same.....
post Sep 25, 2010 - 6:20 PM
block
Joined Jul 27, '06
From Soda
Go to autozone and get the foglight wire kit. It has a how-to and it's very simple. I did it on my celica and corolla with ease and all within 20 minutes.
post Sep 25, 2010 - 11:13 PM
AdrianF
Joined Mar 14, '10
From colorado
thank you all for the help
(\__/)
Lo-Fi Version Time is now: November 27th, 2024 - 6:49 PM
