> AMP
post Sep 25, 2010 - 4:24 PM
e30og
Joined Sep 24, '10
From Maryland
anyone want an amp wiring how to...or is this pretty much well known? might hook one up in the somewhat near future and i can post a how to if needed
same skidpad grip as a 2006 M3....stock. 'nuff said
post Sep 25, 2010 - 6:10 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Run the power wire from the rear through the passenger side, under the carpet, and through the hole in the firewall where your wiring harness goes, then around the inside firewall from the passenger side to the drivers side then to the battery. ( Dont forget to get like a 220 fuse for the power wire, just to be safe ). Then find somewhere to run your ground wire too, which is really simple. The run your RCA cables and remote wire to stereo, hook it up, your done. It took me 45min-1hr to do it that way with no wires showing or anything like that. I really hate wires.
post Sep 25, 2010 - 9:25 PM
mkernz22
Joined May 10, '10
From MA
you should run the wire to the battery on the driver's side and drill a hole in the fire wall. You want to have the power wire as short as it can be because if you run too much, it won't run at peak power, the energy will get lost during the way.
post Sep 28, 2010 - 7:50 AM
H1gherReflex
Joined Feb 21, '10
From Elizabethtown, KY
Go ahead and make one. I'm not too familiar with wiring period.
HONDA
Hold On Not Done Accelerating
post Sep 28, 2010 - 1:51 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (mkernz22 @ Sep 25, 2010 - 10:25 PM) *
x2. And run the RCA cables on the opposite side as the power wire. Wiring is fairly well known, but go ahead and make a how-to anyway. Other forums have how-to's for everything and ours has nothing.
This post has been edited by richee3: Sep 28, 2010 - 1:52 PM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 28, 2010 - 10:34 PM
e30og
Joined Sep 24, '10
From Maryland
Awesome, well hopefully Ill get time this weekend or something, just starting work (thank god). and yea I should definitely run it on the drivers side. Still deciding if I want the amp for all of the speakers or just the sub/s, especially if I replace the front door with 8inch instead of 6.5.
I'll probably end up just wiring everything just in case, so If I decide to do everything with the amp, just have to plug n play the speakers
Lo-Fi Version Time is now: November 23rd, 2024 - 3:29 AM
