3 Pages V  < 1 2 3 >
> How difficult do you think it would be to get from Fwd to Rwd?
post Sep 26, 2010 - 8:15 PM
mkernz22
Joined May 10, '10
From MA
5th gens were fwd
best of my luck to you man if you're really going to do the RWD conversion!
despite what everyone else says, I think it would be a great project. I would do it myself if I had the money because it would be a one of a kind for the 6th gens.
I've noticed that when someone goes to do something that has never been done, people are always against that idea, but when someone accomplishes something that no one else has done, then people want to do it what that person did.
post Sep 26, 2010 - 9:40 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (Smaay @ Sep 26, 2010 - 9:02 PM) *
celicas were all RWD untill the 5th gen or was it the 4th?
Gen 1-2-3 were Rwd, then 4-5-6-7 were fwd. In fact, Fwd appeared on the celicas as the Gt-four came out for the first time.
post Sep 26, 2010 - 9:44 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (mkernz22 @ Sep 26, 2010 - 9:15 PM) *
5th gens were fwd
You know what?
That's EXACTLY what went through my mind 1 minute before reading your post. And that's what I plan to do. But I will never do it in any time soon. I'm only 19 and have a very SMALL budget since I'm still at school. But later I will have the abilities to do everything on my car and I will also have the means to do it too.
But for the moment, I'd like to have more power so I thought of the 3s-gte, but man.. I don't think this power in a Fwd car is worth it but it would still be better than the 5s-fe there already is in it.
So I think that for the moment I'll just keep it very clean and put money into it so that it looks good. And then, only then, when I'll have the knowledge and means to do it, I will surely do the Rwd convertion, and then 3s-gte smile.gif.
Until then, I'll keep daydreaming lol
This post has been edited by dudeofchaos: Sep 26, 2010 - 9:47 PM
post Sep 27, 2010 - 9:09 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
Sorry to tell u this but no u won't have thw first rwd 6th gen it has been dun before. I am also currently doing my own with the alteza 3sge black top for my high performance grad project.
This post has been edited by hatchy_gt-s: Sep 27, 2010 - 9:11 AM
post Sep 27, 2010 - 9:23 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
Best thing to do is get a rwd donor that has or uses the same engine family that you want to use.
Also it probably won't be net as hard as everyone makes it out to be. You just need to be practical about how everything is set up and keep it all simple. Of course this is coming from the guy that is building a 70's civic to be a rwd motorcycle powered road racer with a space frame.....
Coming in 2010
post Sep 27, 2010 - 9:51 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok if you really want to go RWD its not that hard. get a full ST205 clip, take the tranny to a fabricator and have them weld the ports for the front axles closed. fab up the supports for the rear end and install that. thats about it, you are done. but why go through all that when you can have AWD.
AWD > RWD but then again it all depends on your application
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 27, 2010 - 9:56 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
QUOTE (hatchy_gt-s @ Sep 27, 2010 - 9:09 AM) *
yes what hatchy is planning on doing is correct.
if i wasnt planning on selling my car i would have done the same thing...the I.S. beams motor with tranny and using the gt4 rear diff.
the only difficult part would be deciding which steering rack to use...im not totally sure but i think the I.S. one would work but it will require some custom work. motor mounts for the motor would have to be custom, and the drive shaft would need to be custom and then the firewall would need to be cut. unless you use a tube front frame. (HARDTARGET has done this before but he used a tube front end and im not tottaly sure but his was made for track use.)
post Sep 28, 2010 - 9:12 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
Oh, too bad if I'm not the 1st one then. I'll still be freakin proud haha
post Sep 28, 2010 - 10:09 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Ehh, don't start planning stuff out that far ahead. Stuff, life, and goals change so quickly... No offense but after a few years of the same car, you'll probably realize there are better ways to spend your money, car related or otherwise.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Sep 28, 2010 - 5:26 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (czwalga @ Sep 28, 2010 - 10:09 AM) *
Maybe. But I seriously don't think I'm going to change any time soon. The only thing I have in life is my car so there's nothing else I could spend my money into. Of course my life will change in the futur, but I doubt it will change enoght in a few years to change my mind. But I understand what you say, it's all true. Let's just hope I won't go this way tongue.gif
post Sep 28, 2010 - 8:53 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
You shall change your mind ! haha jk, good luck bro, and what said about you could get the RWD black top BEAMS and use the GT4 rear diff that would prolly work out well.
Talk to Keith at RPMGarage, hes pretty cool and easy to work with. He's sourcing some S15 parts for me right now, so im sure he could find that setup easily.
post Sep 29, 2010 - 6:00 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (dudeofchaos @ Sep 28, 2010 - 5:26 PM) *
I just know my last year of college, I went from having a supercharged mustang with a built rear. Was going to make it a 8 second car. Then I was buying a Viper GTS when I graduated, then I was buying a C6Z06, what end up happening was I sold my mustang, bought an rx7 and did a 2 year build on it. biggrin.gif
-10 F150
post Sep 29, 2010 - 2:52 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
QUOTE (JuMPiiN @ Sep 28, 2010 - 8:53 PM) *
Why go with BEAMS engine instead of 3s-gte?
post Sep 29, 2010 - 4:41 PM
richee3
Joined Jun 29, '08
From Denver
The 3S-GE Blacktop BEAMS came in the Toyota Altezza and is already configured for RWD. It's mounted longitudinally, not transverse. The 3S-GTE is transverse mounted. So the Blacktop BEAMS is a better choice for a RWD only setup as far as mounting is concerned.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 29, 2010 - 4:52 PM
JuMPiiN
Joined Nov 10, '09
From Louisiana
Exactly what he said above.
post Sep 29, 2010 - 6:21 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
probably be better off buying a coroll ae86 and doing an 3sge blacktop in their, and then get the weight ration perfectly at 50/50. since the 3sge is heavier than the 4age. im not putting you down or anything just a suggestion
post Sep 29, 2010 - 7:34 PM
mkernz22
Joined May 10, '10
From MA
also with the beams, you could turbo it, it wouldn't be that hard at all.
post Sep 29, 2010 - 7:53 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (mkernz22 @ Sep 29, 2010 - 8:34 PM) *
no!
post Sep 29, 2010 - 9:54 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Johnnyny @ Sep 29, 2010 - 8:53 PM) *
no!
haha yes I agree N/A all the way check out this video, this is why I love N/A engines!! http://www.youtube.com/watch?v=iHmP-xUK6-E
post Sep 29, 2010 - 9:56 PM
mkernz22
Joined May 10, '10
From MA
so i guess i shouldn't have mentioned that lol...
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: November 23rd, 2024 - 2:31 AM
