> Installing water temp gauge on 7AFE, help?
post Sep 26, 2010 - 12:20 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
I have a SunPro water temp gauge and the temperature sender is too big to fit in the thermostat housing, so does anyone know an alternative place to put it? And if not, is there anywhere to put it to be an oil temp gauge?
post Sep 26, 2010 - 10:22 PM
95celicastLSR
Joined Nov 16, '06
From Findlay,Oh
im not sure of the brand but i was looking around and found a universal insert that you put in between your radiator hose and engine and it has adapters to fit pretty much any water temp gauge just look it up on yahoo... ill check for you 2maro man ...
post Sep 26, 2010 - 10:44 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
I've seen that on the internet before too, In fact when I was trying to install the other gauge I was wishing I had it. I took that other gauge back already so it'd be great if you found what brand it was biggrin.gif
post Sep 27, 2010 - 3:00 AM
mgnt232
Joined Mar 16, '09
Glowshift makes the coupler things smile.gif I was looking into doing it for mine, just never got them. If you do it, you should do a little write up while you go along, so people in the future can know exactly what to do smile.gif
►Water Temp Link◄
►Oil Pressure Link◄
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Sep 27, 2010 - 6:16 PM
beefstrudel
Joined Sep 26, '10
From Kentucky
Awesome. I'll probably work on it this weekend, I'll write up some instructions and I'll take some pics too. biggrin.gif
post Sep 28, 2010 - 7:55 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
problem with in the hose is you create more potential leaks and if you use the hose the t-stat is on you'll never get a real read of engine temp. better to thread an electric sender into somewhere on the block or head where there is coolant.
post Sep 29, 2010 - 2:55 AM
windowlicker
Joined Jul 2, '08
From SoCal
QUOTE (95celicastLSR @ Sep 26, 2010 - 10:22 PM) *
buddy club makes them. their website is www.buddyclub.us its in the products section in the racing spec series sub section.
haven't dealt with these guys, was just a place the came up under google images of the part.
https://www.jhpusa.com/store/pc/viewPrd.asp...;idcategory=609
Lo-Fi Version Time is now: November 29th, 2024 - 6:51 AM
