Firewall hole/Radio kit? |
Sep 27, 2010 - 3:22 PM |
Enthusiast Joined Sep 27, '10 From Laredo Currently Offline Reputation: 0 (0%) |
I was wondering if anyone can help me out on this, im knew to the whole installation system, im wondering where i can get a radio kit for my 1996 toyota celica hatchback? Also where can i run the power wire from battery to amp, do i have to drill a hole or can someone give me some directions as where to run it through? Thanks for the help in advance!
Sep 27, 2010 - 3:44 PM |
Look on crutchfield.com, they're sometimes expensive but will give you an installation guide, customer support, and an installation kit specific to your car (if applicable) for everything you buy.
The 12V power wire can go through the firewall in an existing hole, and it will come out a few inches above the dead pedal in the driver's side foot well. The hole is above the brake booster, it's on the right side of the engine bay (driver's side). This post has been edited by SwissFerdi: Sep 27, 2010 - 3:45 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Sep 27, 2010 - 4:03 PM |
would i have to drill a hole, i looked around that area and didnt see a hole?
Sep 27, 2010 - 4:50 PM |
Nope, mine was already there. The blue wire was there already as well. There's a possibility that the previous owner drilled that hole, and in that case, you can use its location as a template for drilling your own.
Good luck. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Sep 28, 2010 - 1:54 PM |
Just so you know, manuals have a clutch master cylinder there. So that hole, whether it was there from the previous owner or the factory, is inaccessible to those of us with a manual transmission. It's best to drill your own hole after some careful measurements.
The dash kit you can get from Wal Mart or Ebay or pretty much anywhere that sells dash kits. That's easy enough to find. This post has been edited by richee3: Sep 28, 2010 - 2:00 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Oct 16, 2010 - 4:35 PM |
Enthusiast Joined Sep 12, '10 From Scottsboro, AL Currently Offline Reputation: 0 (0%) |
I dont mean to steal the question here but is this not always a problem?
I looked at walmart and the only intallation kit i found had 5th and 7th gen but not ours. I bought it anyways thinking theres no way it could be THAT different but its like a quarter inch too wide for the console. The radio i have flips down like its supposed to but is catching the console and i cant push it in. i guess i dont have the right one already in it... I just cant find a new kit anywhere. any luck? EDIT: well, i finally had an epiphany this evening. my radio goes in from the outside. OMG ha i can drop a transmission but ask me to put a square peg in a square hole..... i had to grind down the console a bit, but it fits tight and looks good. so scratch all that. This post has been edited by nwizzle: Oct 16, 2010 - 8:07 PM |
Oct 16, 2010 - 5:10 PM |
our cars dont use kits, you can make holes on the radio brakets 0.5 or 1cm away from original hole depending on the locations.
Oct 16, 2010 - 5:15 PM |
oh and dont do this. it will make you leak!!! this is on the door jamb. big error...
This post has been edited by njccmd2002: Oct 16, 2010 - 5:15 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Oct 17, 2010 - 11:40 AM |
Enthusiast Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
if ur car is a manual, u can run the power wire through the same place the clutch goes through.. thats what i did and ia havent had any problems in the past 3 years
Nov 9, 2010 - 12:01 PM |
Where can I get a radio dash kit to install my radio in my celi?
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:57 PM |
