35 Pages V  « < 9 10 11 12 13 > »
> 6th Gen Celica Rally Car AWD Build, Rebuilding after the roll.....
post Jun 6, 2011 - 12:00 AM
cjh4l22
Joined Oct 18, '06
From cincinnati
4gr is a good idea and why wouldn't a 3sge bolt up? its VERY similar to a 3sgte
post Jun 6, 2011 - 6:49 AM
Culpable04
Joined Apr 17, '06
From New Jersey
the 4grfse would be a decent engine for this and it does mate to the AWD e154F, problem would be cost and wiring. is a relatively new engine which will make it hard to find and expensive, and since noone that I know has installed this engine on a Celica, it'ld be a new path that will come with its set of challenges, as much as I'd love to see this engine installed, I think beause of time limitations and the fact that once he advances on the racing program he'll upgrade the engine anyways, I think a cheaper / easier to install engine is better suit for his application.
so that send us back to 3sge / 3sge BEAMS which will require minimun wiring work to get going, mounts match and at most they'll require some grinding to the block that he has done before and won't be much of a road block.
post Jun 6, 2011 - 7:09 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
3s-ge and gte are very similarly laid out motors, while the internals differ vastly, alot of the ancillaries almost identical if not interchangeable.
Mike W
269awhp / 273ft-lbs
post Jun 6, 2011 - 7:32 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (SupraKid @ Jun 5, 2011 - 7:31 PM) *
I dont understand, You don't want to get a beams because of the rarity of parts? But a 3sge is ok? Are non beams parts that much easier to find?
Well the fact that the non-beams is 1k less in price might have something to do with it.
As far as grinding the block... I thought the 3sge and GTE had the same exact block?
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Jun 6, 2011 - 8:48 AM
Culpable04
Joined Apr 17, '06
From New Jersey
you may be right, I coudln't confirm that with part numbers, but I've read of people using 3sge ( beams and regular ) cylinder block as a base for the 3sgte builds so you can very well be right about it and save yourself the grinding step.
post Jun 6, 2011 - 11:53 AM
mak5603
Joined Oct 20, '08
QUOTE (mkernz22 @ Jun 5, 2011 - 4:42 PM) *
Isn't the non beams just a 3sgte without the turbo? Should be the same gaskets and internals
Not true at all.
2014 Toyota Rav4 XLE
post Jun 6, 2011 - 3:09 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Found a pic on stage before the engine blew.
-10 F150
post Jun 6, 2011 - 3:12 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
nice =D
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Jun 6, 2011 - 4:20 PM
delusionz
Joined Feb 11, '08
hmm,3sgte stronger pistons, rods, crank, oil squirters, metal headgasket, lower compression (bigger) head chambers, different cam profiles (peak power at earlier).
Mike W
269awhp / 273ft-lbs
post Jun 6, 2011 - 8:07 PM
Success21
Joined Nov 18, '09
From Worcester, Ma
Well why not just build a 5sgte. Then save the turbo for later. So essentially a 5sge.
2003 Matrix XR - Daily Driver
1996 Celica ST - In Progress
1995 Camry LE - totaled :(
post Jun 7, 2011 - 7:52 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (Success21 @ Jun 6, 2011 - 8:07 PM) *
Building an engine at this point will take more time and be more costly. I'm looking for something fairly easy... i've been neglecting my house, girlfriend, dog, etc. hahaha over the last two months trying to get the car done. So now i need some time for other things.
-10 F150
post Jun 7, 2011 - 5:22 PM
chacha
Joined Dec 29, '05
From So-Cal
amen, i've done the opposite of you C, let me take care of your car.
post Jun 7, 2011 - 7:33 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Anyone have any links for the 3sge wiring swap? I'm really not worried, it can't be any worse than the rx7 was, but I'd like to know generally what is required. I searched for 3sge, but haven't found much in terms of wiring.
-10 F150
post Jun 8, 2011 - 1:28 AM
Rusty
Joined Nov 5, '07
From New Zealand
People these days usually swap to 3sgte or a beams there are a few on here which have swapped/going to. I think the wiring would be easier than the beams/ 3sgte
As for parts they should be cheaper, still might be a bit of a hassle with availability due to the 3sge not for sale in the usa
I've also pm'd you with some 3sge wiring diagrams
post Jun 8, 2011 - 6:45 PM
enderswift
Joined Jul 12, '08
post Jun 10, 2011 - 8:59 AM
czwalga
Joined Sep 27, '10
From pittsburgh
I bought the 3sge non beams. Should have it next week. Like I said i'm trying to start slow; even the top $200k+ cars are only have 285 hp/350 tq, different than a lot of other racing. Don't need that much HP to get yourself into trouble.
Need to change brakes/rotors/front axles on my audi to get it to pass inspection. Have to work saturday, off sun/mon. So sunday i'll be working on the audi. Monday I'm going to pull this engine, hopefully have soom good carnage pics.
-10 F150
post Jun 12, 2011 - 7:54 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Assholes that inspected my audi torqued the wheel bolts to over 200 ftlbs. Torque spec is 90. Broke a bolt head off; now cant remove the wheels.
I did manage to get the celica around the back of my house and into the workshop. Barely made it as there's a hill to get in. I had to get a running start. Floored at in neutral it wouldnt rev higher than 3k rpms. Sounds like a healthy engine to me! owned.gif
This post has been edited by czwalga: Jun 12, 2011 - 7:55 PM
-10 F150
post Jun 12, 2011 - 8:49 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
QUOTE (czwalga @ Jun 12, 2011 - 8:54 PM) *
Man I feel for you. I'm always scared to let anyone else touch my car. I'm looking forward to the 3sge swap.
post Jun 14, 2011 - 4:45 PM
czwalga
Joined Sep 27, '10
From pittsburgh
So I tore the engine down yesterday. Rod bearings in cylinders 2 and 3 were gone completely. Not even spun, just gone. Crank and rods are scored pretty good.
Some of these are a bit old.
Exhaust I made.
1/4 inch aluminum skid plate. Already has some big dents in it.
3sge
Hard to tell but the crank and pistons are really scored...
-10 F150
post Jun 14, 2011 - 5:05 PM
czwalga
Joined Sep 27, '10
From pittsburgh
-10 F150
Lo-Fi Version Time is now: November 23rd, 2024 - 6:07 AM
