35 Pages V  « < 14 15 16 17 18 > »
> 6th Gen Celica Rally Car AWD Build, Rebuilding after the roll.....
post Sep 28, 2011 - 12:19 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
let me say a great respect from the work you did to build the car thumbsup.gif
and does i advise you to use a pipe instead the rubber hose from the radiator to the thermostat/water pump, the engine thanks you this especially on a race care
where the rpm's are high a long time
statically there is a pressure over the atmosphere but dynamically when the thermostat is opened you have a lower pressure becouse of the water pump which makes the
rubber hose pull together they higher the rpm's which can affect the water flow in worst case by up to 70%
greetz
This post has been edited by Sunny: Sep 28, 2011 - 12:21 PM
KEEP COOL UNDER PRESSURE
post Sep 28, 2011 - 3:13 PM
qatar11
From Lake Orion, MI
Very late to the game to all of this... fantastic work I have some questions as I am thinking of making the jump from 24 Hours of Lemons / Chump Car to Rally America / NASA....
1) I saw all the stitch welding... Was there a decision to do this over seam welding? Is seam welding not practical / not enough upside / verses the stitch welding?
2) What class do they have you running in? Your engine / drive line combination technically wasn't a factory option, It "sounds" like they didn't dump you into open
3) Does NASA have the same no Noobs allowed to run turbo AWD like RA? From what I hear, the Turbo AWD setup just lets you fly into the trees at a greater speed anyway smile.gif
4) Whats your take on spare parts during the rally itself? I was going to steer clear of running a ST205 in rally for the lack of spare parts...
5) On that same note... I assume you are not running the super strut up front
6) If you are thinking of running Sno*Drift, you have a guy or two here who would love to crew for you
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 28, 2011 - 3:19 PM
qatar11
From Lake Orion, MI
7) How different is NASA / RA rule book wise?
8) I know there were logistical reasons to go AWD first but did you have rally experience before running this car? "Most" people I've talked to communicated a lot of important lessons were to be learned rallying FF first...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Sep 28, 2011 - 7:25 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (qatar11 @ Sep 28, 2011 - 3:13 PM) *
1. Well they are kinda the same thing just whether its continuous or not. I think stitching is good enough, plus with a continuous bead youll get too much heat buildup and warp the shell more.
2. I'm running in Open Light, basically means any mods I want with AWD as long as its N/A and under 2.65 liters.
3. NASA does not, you can run an open class car without any experience. I personally think its stupid to start in a car where you can only race in half of the sanctioned races though.
4. I only take stuff I have a chance at 'changing'. I take spare axles, fuel pump, stock struts/springs (just incase my coilovers blow up and atleast i'd have something). I have a spare transmission in my garage but dont take it.
5. Nope, Mcphereson type... honestly I dont know why lots of people get all jazzed up on here about superstrut and try to convert. It's a perfect example of trying to over engineer something.
6. I will be at sno*drift unless something really changes with my plans. I'm not sure what my normal crew situation looks like, but you should atleast volunteer, you get to see a lot of action. Probalby work a start/finish control one day then marshall a spectator area another. wink.gif
7. NASA/RA they are very similar but there are some main differences. RA doesnt require FIA seats, also can't run an open or group 5 car without enough exp. They require a few more items like spill kits and such. Cage design varies slightly, but its easy to make it legal for both.
8. I have no rally exp before this. Lots of people say that and I'm not sure I disagree, but really i think the biggest reason is to 'learn how to drive a slow car fast'. Well i'm still doing that its still slow. I wasn't planning on converting this to AWD atleast yet. However when I was able to get the AWD stuff for about the same price as Clutch/Plate differential (kaaz) i said why not.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Oct 9, 2011 - 2:48 PM
ricochet1490
Joined May 3, '11
From Ohio
post Oct 9, 2011 - 5:10 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (ricochet1490 @ Oct 9, 2011 - 3:48 PM) *
I come back the 22nd or something.
-10 F150
post Oct 9, 2011 - 5:45 PM
mkernz22
Joined May 10, '10
From MA
Just an FYI, I'll have those rims sent out this upcoming weekend. I've been busy with college work kindasad.gif
post Oct 23, 2011 - 6:02 PM
czwalga
Joined Sep 27, '10
From pittsburgh
Back from korea... finally.
-10 F150
post Oct 23, 2011 - 6:12 PM
ricochet1490
Joined May 3, '11
From Ohio
light bar?!
post Oct 24, 2011 - 3:42 AM
chacha
Joined Dec 29, '05
From So-Cal
QUOTE (Sunny @ Sep 28, 2011 - 1:19 PM) *
Hi,
greetz
that is a beauty...i would love to have one of those
post Oct 24, 2011 - 6:23 AM
qatar11
From Lake Orion, MI
QUOTE (ricochet1490 @ Oct 23, 2011 - 7:12 PM) *
light bar?!
It's probably removed for daytime rallying... would hate to blow up all those lights when your not using them...
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Oct 24, 2011 - 4:22 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (qatar11 @ Oct 24, 2011 - 6:23 AM) *
light bar?!
That's exactly it. A new bumper is cheaper than the lights haha.
This post has been edited by czwalga: Oct 24, 2011 - 4:23 PM
-10 F150
post Oct 27, 2011 - 11:36 AM
FastLane95GT
From Modesto, CA
epic thread. props to you sir.
post Nov 9, 2011 - 7:09 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Cutting a a big hole in the floor. I need to completely redesign the seat brackets and floor. I'm too tall and do not have enough headroom. Over big bumps my head hits the cage.
The seats already on the floor soo... only way to go is down. I also bought a drill press... cant believe I waited this long, so much easier to drill metal than a hand drill.
Start of the seat brackets...
-10 F150
post Nov 9, 2011 - 2:00 PM
good geeze, how tall are you dude!
how much are you recessing the floor pan?
I'd be slightly concerned with ground clearances.
This post has been edited by playr158: Nov 9, 2011 - 2:01 PM
post Nov 9, 2011 - 3:50 PM
czwalga
Joined Sep 27, '10
From pittsburgh
I'm 6'2", but you have to figure with a cage and helmet you're talking atleast 3 inches gone just from that if there's no space between the two.
I'm only moving it down about an inch. The front of the seat will still be above the floor pan level, but the seats are fixed back and sit on an angle.
Really most of the problem was on the inside where the tunnel was.
-10 F150
post Nov 9, 2011 - 3:53 PM
Gotcha,
post Nov 9, 2011 - 5:04 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (czwalga @ Nov 9, 2011 - 3:50 PM) *
Would love to see pics when this all gets done, I'm 6'4" and have a sunroof... so I have no headroom. I have to tilt the seat back and its getting annoying, never mind if I had a helmet on. biggrin.gif
post Nov 11, 2011 - 4:03 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (jcbass7 @ Nov 9, 2011 - 5:04 PM) *
yeah more than 6'2 and ppl dont fit into celica's, im 6,4 and i have problem whit the fitment of my seat, im about to try it whitout the rail, if it doesnt works well, you gave me a great ideas what my next job will look like frown.gif
post Nov 11, 2011 - 4:30 PM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (Needles @ Nov 11, 2011 - 4:03 PM) *
Without a helmet/cage you should be fine; atleast from cutting out the floor. There stock seat is a good amount off the floor, so you probably have an extra 2 inches before you get the to bottom if you're using the stock rails.
Might have to get creative, but I dont think you'll have to cut the floor.
-10 F150
Lo-Fi Version Time is now: November 23rd, 2024 - 9:28 AM
