6th Gen Celica Rally Car AWD Build, Rebuilding after the roll..... |
Apr 23, 2012 - 8:08 PM |
Enthusiast Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
Well painted the car.... too much blue. Should have painted the whole thing. The fenders/bumper I got were brown so obviously its better blue than brown, but ehhh. The lines don't flow well, maybe itll look a little better once I actually get everything on. Might have to get some white fender stripes or something. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Apr 23, 2012 - 8:26 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
dude... this thread is full of sooooo much win. freaking awesome
Apr 23, 2012 - 10:10 PM |
Very awesome. Can't imagine doing half of the stuff you've done, very impressive.
Apr 23, 2012 - 10:32 PM |
in my minds eye, this is going to look freaking awesome....... loving the blue front and top with white bottom and rear
This post has been edited by ricochet1490: Apr 23, 2012 - 10:32 PM -------------------- |
Apr 24, 2012 - 1:02 AM |
Maybe make a line that flows with the pillar and top of the door and into the fender, paint what's below that white to match the rest of the car. Try and make a nice transition. That's just my OCD talking though.
Apr 24, 2012 - 8:28 AM |
Maybe i'll paint the lower sill blue, 2 white fender stripes should make it look better.
It's painted with a single stage paint so I wont attempt to wetsand and buff it, so it wont be a mirror like the rx7 paint, but it's a rally car. From 5 feet it looks almost the same. The single stage was a lot cheaper than a dual stage urethane by a few hundred dollars. This post has been edited by czwalga: Apr 24, 2012 - 8:30 AM -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Apr 24, 2012 - 9:33 AM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Great work!
You mentioned in my "progress" thread; FYI, do you have a separate? The coil is separate from the distributor unlike the 5sfe, also doesnt bolt the engine bay so it most likely didnt come with one. What did you use? OEM or did you go aftermarket? (MSD, etc) -------------------- |
Apr 24, 2012 - 11:15 AM |
Great work! You mentioned in my "progress" thread; FYI, do you have a separate? The coil is separate from the distributor unlike the 5sfe, also doesnt bolt the engine bay so it most likely didnt come with one. What did you use? OEM or did you go aftermarket? (MSD, etc) I used OEM. I was able to use ToyoDIY, cross reference the part number for the 3sge and find out which cars in the USA use the same coil. I end up going to a pic-a-part and getting one off a 98 rav4 for like 20 bucks. Here's the part:90919‑02209 According to some websites it fits my exact model, but I know for a fact that the distributor that came with my car, vs the 3sge were not the same. My distributor had an extra plug for the coil. The 3sge needed that part. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Apr 24, 2012 - 12:07 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Pro tip of the day - if you start to get a misfire at higher RPMs that gradually starts to fall lower into the RPM range as the engine gets hotter and hotter - replace your coil pack with a new one.
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Apr 26, 2012 - 5:14 PM |
Sprayed the bottom sill yesterday. Flows a lot better.
Apr 26, 2012 - 5:22 PM |
Awesome, can't wait to see an updated pic.
May 6, 2012 - 6:18 PM |
Alright the celica is reassembled. Need to tie up a lot of loose ends on the car before STPR which is a national rally in north central PA. June 1st/2nd.
Looks a little plain right now, but once i get some event stickers on there itll help. Also working on the Rx7. I had to chop up and redo the piping to the turbo. I changed exhaust housing to a bigger AR ratio. The old housing was on-center, the new one is tangential. So the physical location changed. I also gave myself more room this time so I end up running 3.5" exhaust the entire way back, instead of 3" for a bit, then stepping it up to 3.5". 3.5" is the biggest I can fit. 4" would probably be ideal for max power. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
May 6, 2012 - 6:30 PM |
Looking good!
May 7, 2012 - 10:55 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
So jealous
May 19, 2012 - 2:31 PM |
Got the Rx7 tuned today. Final tune numbers were 725rwhp/760rwtq on 93 octane., 21 psi. Video was the first pull that was cut short due to some knocking, but its the only vid I have.
http://www.youtube.com/watch?v=3k74bFTRr9w&feature=g-upl Once again this was an initial pull, not final tune. Now I need to get busy on the celica to get ready for STPR. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
May 19, 2012 - 2:37 PM |
oh my god......
May 19, 2012 - 3:10 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
May 20, 2012 - 7:12 PM |
May 29, 2012 - 4:12 PM |
Getting closer.
May 29, 2012 - 5:15 PM |
Rally setup looks cherry as usual. I just noticed, 213whp @ 3.4 PSI...mishap with the run?
This post has been edited by SwissFerdi: May 29, 2012 - 5:16 PM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:24 AM |
