2 Pages V  < 1 2
> Caliper Locking up
post Dec 31, 2010 - 6:08 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
That sounds reasonable, since there are two separate line for the rear.
post Dec 31, 2010 - 10:46 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Thats probably what it is, how do you tell if you have a faulty proportioning valve, everyone says they rarely break.
post Dec 31, 2010 - 11:18 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
post Dec 31, 2010 - 11:25 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I think there is a different way to check the valve its self as well, pretty much the same though, but instead of hooking up at the calipers you hook up at the valve.
post Jan 1, 2011 - 12:18 AM
Euphoria
Joined May 6, '08
thanks! might be worth trying if they are not too expensive.
post Jan 1, 2011 - 4:47 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
QUOTE (toyodiy)
47150 VALVE ASSY, PROPORTIONING
47150‑20240 ST204 (12/1994 - 07/1999) 1 $256.72
47150‑20290 ST204 (09/1993 - 06/1994) 1
47150‑20380 ST204; W(ABS) 1
Price is not actual price, but only a guideline
JDM ST205
post Jan 1, 2011 - 6:39 AM
Euphoria
Joined May 6, '08
Holy **** lol, think they sell them after market?
post Jan 1, 2011 - 9:32 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Have you replaced the rubber brake hose yet?
post Jan 2, 2011 - 10:59 PM
Euphoria
Joined May 6, '08
I haven't but it bleeds fine so I don't see how it could be blocked.
post Jan 6, 2011 - 7:58 AM
blackthunder
Joined Oct 21, '05
From Okinawa, Japan
well took her to the shop and they found that it just needed a rebuilt caliper. Did that and it works like a dream now. Although I'll keep an eye on it to see if the problem comes back at all. Sadly they also found a torn CV boot, ugh, had that replaced too!
-Dan
1998 SSII Beams, work in progress...
post Jan 6, 2011 - 8:01 AM
Euphoria
Joined May 6, '08
Ah dam, looks like you got out the easy way, im 99% sure its not my calipers.
post May 5, 2011 - 3:38 AM
Euphoria
Joined May 6, '08
Well I've rebuilt both pistons at the back, still have the problem...
So I'm gonna replace the pads and possibly get discs machined and see what happens from there.
Best off rebuilding master cylinder after I've done the other things?
post May 10, 2011 - 5:41 AM
Euphoria
Joined May 6, '08
Well I put on a used disc I had there and the problem seems to be gone /facepalm.
But saying that, it was really rusted and old so maybe thats why it won't lock haha.
post May 10, 2011 - 5:45 AM
brenton1919
Joined Feb 28, '11
u might have air in the line.... are u sure its not the wheel bearing locking up ? ive seen that happen once
post May 10, 2011 - 5:49 AM
Euphoria
Joined May 6, '08
It was only under braking, wheel bearing would be constant, I had a bearing seize in the past aswell.
And you'd know if you had air in the line because the pedal would be soft and lack feel.
Hopefully this will stay good, I took it for a good drive today and it was so much safer under hard braking.
post May 10, 2011 - 7:15 AM
brenton1919
Joined Feb 28, '11
QUOTE (Euphoria @ May 10, 2011 - 6:49 AM) *
alright that sound great.. remember tho u can get little air bubbles in the line it can be hard and go soft and then go back hard. that is also a sign a a whole somewhere or a leak... maybe even a bad brake booster. but you should of had the brake seize after u had replaced the piston, that just seem funny i have never heard that before, i have heard of a blockage. but hmm make sure u keep a eye on that, would wanna be going down the road with no brakes or at a high speed and they lock up lol...... i just remember something i was working on a cadillac on time and her brakes kept locking up a line from her abs rub against her tire, and she had a whole in it which made the abs keep locking up. replaced that line and she was all good to go
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 5:23 PM
