Clutch Thrust Bearing, Clutch Thrust Bearing, how much? |
Sep 30, 2010 - 1:38 PM |
Enthusiast Joined Feb 28, '10 From Crewe Currently Offline Reputation: 0 (0%) |
my thrust Bearing is making a grinding noise, i have had a thrust bearing go in a previous car so i know the sound, i have seen that the replacement bearing can be got form Fensport for £40 ish but i would like to know how much the labour costs are likely to be?
Cheers in advance |
Sep 30, 2010 - 3:14 PM |
Labor isn't something we can guess for you. You'll probably want to replace your clutch while you're in there.
Sep 30, 2010 - 4:09 PM |
Enthusiast Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
Yeah labor costs are different everywhere, and vary from shop to shop.
You may as well as said before replace the clutch, resurface the flywheel while your in there. When I got my car i was looking for prices on labor for replacing my clutch. I got quotes from like 600-1000 for labor, so I just jumped into the project for a few days and did it myself -------------------- |
Sep 30, 2010 - 4:40 PM |
i understand that i just needed a ballpark figure as i have no idea how many hours it will take to do the work. when the bearing went in my last car i did change the clutch but i don't want to replace the clutch in this as it had a fast road/race clutch installed less than 2000 miles ago but i do plan in installing an aluminium flywheel in the process.
Sep 30, 2010 - 6:02 PM |
its a 6 hour job for a good mechanic, so whatever regular shop rate is X6
Lo-Fi Version | Time is now: November 25th, 2024 - 12:56 PM |
