Shifter bushings, Brass Bushings |
Oct 7, 2010 - 8:50 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
First question, will upgrading my shifter bushings really make that big of a difference? i already have the 7th get shifter and aluminum base bushings for my shifter, so how much difference is there?
and will these bushings work? i know they say they will fit a 7th gen celica, tc, yada yada, but alot of the parts off the 7th gen fit our cars, here is the link -------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Oct 7, 2010 - 9:41 AM |
Those will fit. I have them on my MR2 and they make a BIG difference. Can't recommend them enough.
Oct 7, 2010 - 11:01 AM |
Enthusiast Joined Aug 18, '10 From champlin,MN Currently Offline Reputation: 0 (0%) |
I have a set for sale for $20 shipped, exact same thing brand new. Look in for sale section I still have the kit available.
Oct 7, 2010 - 11:04 AM |
Enthusiast Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) |
It depends on what you are considering a BIG difference. Will you knock .5sec off your 1/4 mile...probably not. But will the gearbox feel and engage more directly yes. If your shifter bushings are already worn then it would make a more noticeable difference. But really for under 50 bucks what can you be expecting???
Oct 7, 2010 - 12:42 PM |
Enthusiast Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
It depends on what you are considering a BIG difference. Will you knock .5sec off your 1/4 mile...probably not. But will the gearbox feel and engage more directly yes. If your shifter bushings are already worn then it would make a more noticeable difference. But really for under 50 bucks what can you be expecting??? Not all about power numbers or times. Small mods such as these, polyurethane motor mounts, polyurethane bushings, etc. are just better for the overall feel and performance of the vehicle. -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Oct 7, 2010 - 5:37 PM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
Can someone tell me, I just installed a trd short shifter, do they come with new bushing or can I use this
Oct 7, 2010 - 10:03 PM |
did you get a trd quick shifter, or just the 7th gen short shifter? just the shifter comes with purple aluminum bushings that go under the shifter assembly, these go in the engine bay basically right where the shift cables connect to the transmission
Oct 8, 2010 - 12:58 AM |
Enthusiast Joined Mar 3, '08 From New Zealand Currently Offline Reputation: 1 (100%) |
you can also fitted small bearings in the end of the shifter cables or so I have been told maybe Skate board ones??
-------------------- _______________May COTM 2011_______________ |
Oct 8, 2010 - 2:47 AM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
im buying these tomorrow 9 bucks i cant loose now i need a trd short shifter...
Oct 8, 2010 - 2:57 PM |
Enthusiast Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
you can also fitted small bearings in the end of the shifter cables or so I have been told maybe Skate board ones?? That is actually not a bad idea at all, not to sure if they inner diameter will be small enough for the pin of the shift linkage tho? -------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Oct 8, 2010 - 4:10 PM |
Ive use roller blade wheel bearings, but they dont last the canadian winters.
Oct 12, 2010 - 5:19 AM |
Enthusiast Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
you can also fitted small bearings in the end of the shifter cables or so I have been told maybe Skate board ones?? That is actually not a bad idea at all, not to sure if they inner diameter will be small enough for the pin of the shift linkage tho? The inner diameter of standard skateboard bearings is about .314", slip fit for a 5/16 shaft. outer diameter is about .866 with a thickness of about .275". They sell 8mm but I don't know much about them except they are expensive and used mostly on precision downhill trucks. -------------------- JDM guy made me do it.
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:46 AM |
