> oem toyota heeadlight sealant
post Oct 7, 2010 - 4:19 PM
what do you guys use, i hate to go fot butyl nissan rubber. but any choices besides silicone.
post Oct 7, 2010 - 5:10 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I completely removed the black stock sealant and re did it with a clear sylicone I found at autozone, worked perfectly on my pass side one, but since is clear I missed a spot on the driver side one and now it has a little condensation so I guess I'll be re doing that one.
post Oct 7, 2010 - 6:09 PM
the projectors have a grayish silicone type. nissan sells it in black. i have heard silicone is tougher to take apart.
post Oct 7, 2010 - 6:13 PM
Culpable04
Joined Apr 17, '06
From New Jersey
the one I used you just need to heat it with a heat gun to pray it open, just like OEM, the only reason why I remove the oem glue, is because I needed to seal it with something anyways, and was afraid of not working properly is residue of the old one was still present, so I cleaned everything out and apply the clear one. maybe next time I'll use the hot silicone that comes with sticks with a heat feeder gun. that should work as well and it doesn't need as much heat to pray open.
post Oct 7, 2010 - 9:24 PM
azian_advanced
Joined Apr 18, '05
From Calgary
I used clear silicone for mine as well. It's the same stuff as whats holding my fog lamps in place. I haven't installed the lights since I've sealed them so I can't give any feedback yet on how well basic silicone performs.
post Oct 8, 2010 - 10:40 AM
well in case anyone wonders
wd 40 removes it with a little elbow, used a heat gun to get all the chunks away and the remainder with wd
post Oct 8, 2010 - 8:42 PM
azian_advanced
Joined Apr 18, '05
From Calgary
cleaning the glass lenses is the easy part.. wait till you start cleaning the housing.. laugh.gif
post Oct 8, 2010 - 10:29 PM
yeah, i know!
post Dec 3, 2010 - 7:33 PM
cleaning the housing was easy with red scoth brite and wd40
and for those who need sealant... yeah its nissan!!!
Lo-Fi Version Time is now: February 21st, 2025 - 6:36 AM
