DIY Quarter Window and Window Trim Removal |
Oct 12, 2010 - 12:39 PM |
Enthusiast Joined Aug 15, '10 From UK Currently Offline Reputation: 0 (0%) |
Hiya folks...having seen this question asked a few times. I have been busy customising/restoring my Celica so put together a DIY with pictures to help.
1. Remove door weatherstrip. 2. Weatherstrip end clips to be removed...a sealant glue may also be used on the ends but easily removed. 3. Using clip tool to pop off clips...screwdriver works as well. 4. Weatherstrip removal exposes screws to be removed next. 5. Door edge trim removed. 6. Top window edge removed. 7. Removing seat belt top...flip up cover to expose bolt to be removed. 8. Removing coat hanger...pop off cover to expose a screw to be removed. 9. Remove speaker grill to expose screw to be removed. 10. Remove door lip trim and push interior trim off door edge. 11. Pull interior trim out a little to expose a philips headed plastic clip to be removed. 12. In boot area behind seat there is another philips headed clip to be removed. 13. Now you pull off the interior window trim off...held in by several clips...take your time. 14. Continue to pull trim off completely...place out of way for window removal. 15. Tape up the outside of window to avoid breaking it. 16. Using an extendable knife of good quality. 17. Cut into window sealant...go around the whole window. This will take a while...you will feel the blade hit metal once you are through all the way. 18. Quarter window and trim removed. 19. It is quite surprising how much sealant is used on these windows... Grab yourself a cold drink...job done! This post has been edited by CelicaHD2: Oct 12, 2010 - 3:51 PM |
Oct 12, 2010 - 2:11 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Nice write up - vote for sticky
-------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Oct 12, 2010 - 6:41 PM |
Oct 13, 2010 - 9:08 AM |
Oct 13, 2010 - 6:31 PM |
Enthusiast Joined Jun 9, '07 From Miami, FL Currently Offline Reputation: 9 (100%) |
Good stuff, should be stickied for sure.
Oct 13, 2010 - 9:57 PM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
awesome!! i bet lots of people will find this handy!
sticky! -------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Oct 17, 2010 - 10:20 PM |
Enthusiast Joined Jan 11, '07 From Fort Lauderdale, FL Currently Offline Reputation: 0 (0%) |
finally someone has pics on this. you are the quarter window god.
question. what will be needed to remove all the left over sealant, elbow grease? some kind of goo-gone? This post has been edited by gabyz: Oct 17, 2010 - 10:21 PM -------------------- |
Oct 18, 2010 - 1:49 PM |
I used the same knife I used for cutting out the window and cut off most of the sealant...then used a razor blade to trim to further down.
You can buy "sealant removing" chemicals or a rubber "decal removing" wheel but is not necessary. As long as you have no more than 3mm of sealant left...that is perfect for re-fitting of the glass. This post has been edited by CelicaHD2: Oct 18, 2010 - 1:52 PM |
May 6, 2015 - 6:38 AM |
Enthusiast Joined Jan 2, '13 From timothy0 Currently Offline Reputation: 0 (0%) |
Last step is hard. Take your time and use an extended knife of good quality.
This post has been edited by Timothy: May 19, 2015 - 5:33 PM |
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:03 AM |
