Ignition Wires, Anyone ever replace those? |
Nov 25, 2003 - 11:23 AM |
Enthusiast Joined Jun 22, '03 From Toronto, Ontario, Canada Currently Offline Reputation: 0 (0%) |
I was just curious if anyone ever changed their ignition wires, and if there was any benifit to it? I've got 250,000 mi on my original wires ..
Thanks. Shaun |
Nov 25, 2003 - 11:57 AM |
Enthusiast Joined Sep 18, '02 From Masachusettes Currently Offline Reputation: 0 (0%) |
i replaced my st ignition wires with the vitec ones. just because i wanted the yellow ones and i thaught they would be bigger but i was wrong ohh well they look better than stock thought. they even came with a sticker that said vitech so i took off the i and sold it to a pu$$y honda owner for 30 bucks and told him to put a type r sticker right next to it. i basically got the wires half off
Nov 25, 2003 - 12:26 PM |
Enthusiast Joined May 17, '03 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
yeah, change them. You can cause damage to the ignition system if the resitance in your wires gets too high. Given that the 5S-fe has a distributor, this risk is lower compared to distributorless, but it does affect cold start and performance. The degrading of the wires happens over time and use. I would change the wires every 100K or so because they are not that expensive.
Nov 25, 2003 - 12:29 PM |
Thanks guys! I'm gonna call Toyota right now..
Hope mine aren't too tight to pull out!:) |
Nov 25, 2003 - 3:51 PM |
Oh, some advice on changing them:
only disconnect 1 wire at a time and install the replacement, that way you will not risk crossing wires. you may want to look into some aftermarket ones as well. |
Nov 25, 2003 - 4:02 PM |
Thanks. Good call. Where abouts in Ontario are you from?
Missisauga here:) |
Nov 25, 2003 - 4:41 PM |
Enthusiast Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
It's good to replace your wires every time you replace your spark plugs...
Nov 25, 2003 - 10:18 PM |
Enthusiast Joined Oct 9, '02 From Longmont, CO Currently Offline Reputation: 1 (100%) |
You can get NGK plugs and wires through clubplug.net for a pretty good price. I believe they are based out of Canada too.
-Kaleb |
Nov 26, 2003 - 9:27 AM |
thanks Kaleb!
Lo-Fi Version | Time is now: December 3rd, 2024 - 8:28 PM |
