cai vacuum line |
cai vacuum line |
Oct 21, 2010 - 2:08 AM |
Enthusiast Joined Feb 3, '07 From Sydney Currently Offline Reputation: 0 (0%) |
Hey guy
im not a expert on intakes and i have installed a Injen IS2040 and i don't hear much of a sucking sound. would it be something to do with no vacuum line? i have checked around and not sure where this line is located. If there is no vacuum line, what should i do with the vacuum opening on the intake? thanks in advance |
Oct 21, 2010 - 2:15 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
Go to your local auto parts store and get some rubber caps to plug the spigots up. I have an Injen as well and I had 2 un-used spigots and the MAP sensor hole. I got caps for the spigots and of course, put the map sensor in the hole.
June '12 COTM '95 AT200 |
Oct 21, 2010 - 2:36 AM |
does capping the spigot make a difference?
Oct 21, 2010 - 9:33 PM |
does capping the spigot make a difference? It keeps raw air from coming into your motor. -------------------- taking too long to mod since '09
Oct 22, 2010 - 7:40 AM |
Go to your local auto parts store and get some rubber caps to plug the spigots up. I have an Injen as well and I had 2 un-used spigots and the MAP sensor hole. I got caps for the spigots and of course, put the map sensor in the hole. thats not your map sensor. its the IAT (intake air temp) sensor. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 22, 2010 - 8:08 AM |
thats not your map sensor. its the IAT (intake air temp) sensor. Dammit, I was lied to. Then where's the MAP sensor? -------------------- taking too long to mod since '09
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:08 PM |
