![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
Those specs are correct and no the twin pot calipers of a turbo mr2 is not an upgrade. Stock Celica gt bias is 71% front given it is fwd. With the mr2 calipers as an "upgrade" bias ends up being 65% to the front. You will gain loOks but lose performance.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) ![]() |
Those specs are correct and no the twin pot calipers of a turbo mr2 is not an upgrade. Stock Celica gt bias is 71% front given it is fwd. With the mr2 calipers as an "upgrade" bias ends up being 65% to the front. You will gain loOks but lose performance. hmm so how about the SS-II and SS-III celica equipped with superstrut and twin piston calipers is that a downgrade as well?? -------------------- Group buy to replicate Narrow E series transaxle parts
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
As I pointed out, the pistons cover the same area, but you should get even distribution of pressure across the pads with the 2 pots.
can't you change the bias by getting the splitter or whatever you call it, off an mr2? I mean you need it for the ST to GT upgrade, so would GT to MR2 work?
U mean the proportioning valve? Ur saying get one off the mr2? No way Jose the mr2 is mid engine rwd. If ur gonna upgrade for performance do it the right way. As for looks it's ur car do what satisfies u.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) ![]() |
can't you change the bias by getting the splitter or whatever you call it, off an mr2? I mean you need it for the ST to GT upgrade, so would GT to MR2 work? Wrong, you dont have to change that. And honestly i dont think (if you have the same tires and suspension front and rear) having 60% to the front is a bad thing, i mean it helps take away 1 of the many things the front wheels are intended to do on fwd cars. |
Well i cant say we did not try, you guys notice how the Title does not read "upgrade" anymore. Ill keep looking...
Wonder what the bias is with the GT4 calipers -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
Or the Lexus LS400 bias
![]() -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
Damn so the brake bias gets shifted to the back that's no dice at the track. Although it will take less effort to lock the front up. not nessesaraly, the " theorical " magic number for brake bias is 60 / 40 ( front / rear ) but that will vary from setup to setup, and the importance of modifying your Bias is to use the most grip available while keeping the front locking first than the rear, so if you think about it, as long as his front is still locking the tires before the rear, it is an upgrade, a good one actually, because it will spread the braking force better among all 4 tires, so all 4 tires will work more efficiently at stoping the car instead of the front ones doing most of the job with a 70+ % of the braking force on the front. One of my friends tracks his car every season and his brake bias is 58% front 42% rear with an adjustable proportioning valve, he got to those numbers after a lot of trial an error testing. so Norberto, find a safe area where you can test your brakes, have someone look at your tires ( or video ) and make sure your front tires lock before your rear one, if they do, I'll be the first one to call this a great upgrade, best bang for your buck brake upgrade. -------------------- ![]() |
Damn so the brake bias gets shifted to the back that's no dice at the track. Although it will take less effort to lock the front up. One of my friends tracks his car every season and his brake bias is 58% front 42% rear with an adjustable proportioning valve, he got to those numbers after a lot of trial an error testing. so Norberto, find a safe area where you can test your brakes, have someone look at your tires ( or video ) and make sure your front tires lock before your rear one, if they do, I'll be the first one to call this a great upgrade, best bang for your buck brake upgrade. oooo that sounds like rubber fun! -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
try this with a old set of tires, you don't want flat spots on your good tires lol
I guess Driver preference???
of course, a car should be setup to the driver's taste, but my point is that, This " upgrade " should be called an upgrade. in a perfect world you would want all 4 tires locking at the same time as this would make all the tires work just as hard stopping the car, but in the real world the front needs to be locked just slightly before the rears, so depending on the weight transfer due to suspension and engine position and of course drivers taste we should modify the bias to make the best out of the setup,. if you look at most adjustable proportioning valve setups they are use to lower the bais on the front not to increase it, as manufacturers go for a very safe number making sure the front will locked up before the rear even when we are using crappy tires on the front. so for race / track where tires will be properly maintained they aim to bring the bias closer between front and rear while still keeping the front locking first.
let me hear what you think, as this is not what " I know ", is just what I've understood from some reading I've done and I can be very well misinformed or have misunderstood the data, so some of you should support / contradict what I'm saying so we can all move in the right direction. -------------------- ![]() |
I totally agree with you Stevenson I guess the brake bias with the Mr2 calipers would make it an ideal upgrade but just look at the surface area of the pistons. How much smaller is the Mr2 pad compared. To the stock celicas?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
Just out of curiosity where would you get a brake proportioning valve that you can actually adjust?
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Some reading on how to installl them and their use
anywhere, eBay, Amazon, etc Check here ! This post has been edited by Culpable04: Feb 4, 2011 - 10:26 AM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) ![]() |
Nice find....I feel like doing some double flares now. One thing needs to be said though, if you guys feel confident in your mechanical skills, its an easy install. But if you don't, please do not do this on your own. I can just see the replies "I installed this and then my car wouldn't stop". |
^id be one of those people
I totally agree with you Stevenson I guess the brake bias with the Mr2 calipers would make it an ideal upgrade but just look at the surface area of the pistons. How much smaller is the Mr2 pad compared. To the stock celicas? not by much, but im using celica pads anyhow. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Well in that case it would be too bad of an "upgrade".
I can't wait to make my own thread on my Big brake project with them ls430 monoblocs. -------------------- 98 Celica gt red- totaled deer
Lo-Fi Version | Time is now: February 17th, 2025 - 7:49 AM |
