8 Pages V  « < 3 4 5 6 7 > »
> how to: Mr2 to GT brakes at a reasonable price, Bolt on Caliper Change.
post Feb 5, 2011 - 4:54 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I have to take some time and calculate the ST205 stock Bias, and then install the rear ST205s on my car, depending on how it performs I may need an adjustable proportioning valve, but time will tell.
for now I can say, that this is a great setup for someone who doesn't want to get too complicated and on a budget, it changes your brake bias to improve braking without having to actually play with proportioning valves an such, at a very low cost.
Great Job Norberto !
post Feb 11, 2011 - 1:44 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Someone forgot to mention SS-II non superstrut has the same 2pot as SS-III 2pot, Right Rusty?
Only SS-I has the same 1pot as USDM GT.
Mr2 is a way lighter car than Celica so doesn't need as strong brakes.
Mike W
269awhp / 273ft-lbs
post Feb 11, 2011 - 2:42 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (delusionz @ Feb 11, 2011 - 1:44 AM) *
acutally ss-III and g limited both came with 4th gen 3sge and the mr2 actually weighs 1220kg about the same as the celica, if not a little more if I remember correctly
This post has been edited by BonzaiCelica: Feb 15, 2013 - 4:02 PM
post Feb 11, 2011 - 3:19 PM
Rusty
Joined Nov 5, '07
From New Zealand
Superstrut SS-II and SS-III have Twin Pot front brakes. (And I think the SS-II superstrut brakes were bigger than the SS-III, larger rotor)
SS-II has the Single pot front brakes
But as I pointed out....
The single piston caliper specs (SS-II):
Piston Diameter: 57mm
Piston Count: 1
Total Piston Area: 2551.76mm2 (25.5176cm2)
The twin piston caliper specs (SS-III):
Piston Diameter: 40.4mm
Piston Count: 2
Total Piston Area: 2563.79mm2 (25.6379cm2)
It's only an increase of 12.03mm2 (3.47mm x 3.47mm)
post Feb 12, 2011 - 7:12 AM
delusionz
Joined Feb 11, '08
I thought when we compared brakes (when I had SS-III) that you said yours looked identical?
Mike W
269awhp / 273ft-lbs
post Feb 12, 2011 - 11:24 AM
Rusty
Joined Nov 5, '07
From New Zealand
post Mar 26, 2011 - 7:08 PM
S8S8
Joined May 9, '09
From Brisbane, Australia
QUOTE (Rusty @ Feb 12, 2011 - 6:19 AM) *
Piston Count: 1
Piston Count: 2
Regarding the SS-II having single piston calipers, I have something to add...
My ST202 cut is from a non-superstrut SS-II
Yet it has twin piston calipers:
Here I've used a torch to show the non-superstrut suspension:
And a couple more pics showing the markings:
I'm not a Celica expert, but I'm pretty sure what I have here is a non-superstrut SS-II with twin piston calipers.
Thoughts?
post Mar 26, 2011 - 7:54 PM
yes!!!! you are a lucky man!!!!
post Mar 27, 2011 - 12:43 AM
BonzaiCelica
Joined Apr 24, '08
wow interesting. And for the love of god re size your pics its so annoying when members do that!!
post Mar 27, 2011 - 12:59 AM
Rusty
Joined Nov 5, '07
From New Zealand
From Discussion thread about LSD's in the ST202 SS-2's & SS-3's
QUOTE (Rusty)
then after 97
the SS-2(beams) & SS-3(non & beams) run the same TRD pads, so they should run the same twin pot front brakes
(check Japanese TRD website)...and on Toyodiy (however slight difference in part numbers)
They (ST202 SS-II [BEAMS] & SS-III [BEAMS]) both run "twin pot brakes"... However the part numbers are different, it could mean nothing, or a difference between the two, which is why I didn't add it ....and I sort of forgot kindasad.gif
(example : 1998's SS-II & SS-III)
Would be good if you have time to take measurements so we can compare. smile.gif
post Apr 5, 2011 - 6:29 AM
S8S8
Joined May 9, '09
QUOTE (Rusty @ Mar 27, 2011 - 3:59 PM) *
No worries. What measurements are you after?
post Apr 6, 2011 - 12:48 AM
Rusty
Joined Nov 5, '07
From New Zealand
the same above measurements so...
The twin piston caliper specs (SS-II BEAMS):
Piston Diameter:
Piston Count: 2
Total Piston Area: mm2 (cm2)
and rotor specs
circumference
diameter
width
post Jun 22, 2011 - 11:49 PM
BonzaiCelica
Joined Apr 24, '08
this Sticky thread is useless without pictures!!! norberto jump on it.
Which brings me to another topic, hey S8S8 can you give us that answer. We are curious to know whether SS-II Beams and SS-III Superstrut Twin Piston Brake Calipers are the same size???
post Jun 23, 2011 - 10:34 AM
QUOTE (BonzaiCelica @ Jun 22, 2011 - 11:49 PM) *
Dude, you are so needy, just like andrew, are you sure you two are not brothers.
post Jun 23, 2011 - 1:01 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (njccmd2002 @ Jun 23, 2011 - 10:34 AM) *
ya i know right sorry man. Did you change to flickr. Must be an age thing....
post Jul 13, 2011 - 5:05 PM
S8S8
Joined May 9, '09
QUOTE (BonzaiCelica @ Jun 23, 2011 - 2:49 PM) *
I'll be changing the pads soon and will run the measurements then. smile.gif
post Sep 22, 2011 - 11:16 PM
BonzaiCelica
Joined Apr 24, '08
measurements of the twin piston calipers on SS-II Mcpherson Beams Celica???
post Sep 24, 2011 - 8:20 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE (qatar11 @ Oct 22, 2010 - 3:37 AM) *
Out of curiosity... what is your interest in bigger brakes... what are the current symptoms that you curing with a 2 pot caliper?
Those look like Calipers from a ST165, no? Probably not as they allegedly bolt up without issue.
if this is true someone over on alltrac.net did a write up on how to use tacoma brakes on a st 165/185
i have a set of front gt st204 calipers and i think a set of st185 calipers... perhaps ill measure them when i get a chance.... i also have access to st205 front calipers. maybe ill see what i come up with.
This post has been edited by urbandork: Sep 24, 2011 - 8:23 PM
post Dec 7, 2011 - 3:54 AM
BonzaiCelica
Joined Apr 24, '08
is fensport correct??
if you see this link you see that they mention the ST202 Superstrut Celica, AE111 Corolla Superstrut, MR2 Rev 3 N/A and MR2 Rev 3sgte all use the same brake pads http://www.fensport.co.uk/Parts/Model_14/Category_11/2672
but if you take a looky here on toydiy you can see that the pads from 1999 Celica SS-III Superstrut only share common part numbers with carinna and corona cars. http://www.toyodiy.com/parts/xref?v=J_1999...mp;s=0446520230
Here is the ST202 Mcpherson SS-II twin pot pads. http://www.toyodiy.com/parts/xref?v=J_1998...mp;s=0446520470
here is 1990-1995 SW20 3sgte MR2 http://www.toyodiy.com/parts/s?v=U_1993_TO...1%E2%80%9117160
brake pad : 04491‑17160
for some reason I can't find any part numbers for the Corolla AE111 brake pads. toydiy does not list part #'s
ST202 SS-II Beams Mcpherson brake pads : Part 04465‑20470
ST202 SS-III Beams Superstrut brake pads : Part 04465‑20230
or so I think damn I'm so confused.
This post has been edited by BonzaiCelica: May 8, 2012 - 6:29 PM
post Dec 30, 2011 - 2:10 AM
BonzaiCelica
Joined Apr 24, '08
MR2 Turbo pad
MR2 Turbo pad
Celica SS-III twin piston pads
This post has been edited by BonzaiCelica: Dec 30, 2011 - 3:51 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 3:52 PM
