over heating please help. |
Oct 23, 2010 - 3:44 PM |
Enthusiast Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
hey everyone i just did a throtal body coolant bypass last night and lost a bit of coolant while doing it. i know low coolant can cause the car to over heat but what i accelerate the temp guage goes up and while im at a stop light. when im going along it stays where it should be, could there be a big air bubble in the system? and if so does anyone know how to get it out without draining the coolant.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Oct 23, 2010 - 3:47 PM |
Burp the cooling system.
Oct 23, 2010 - 3:51 PM |
let it cool and open the radiator cap? my car doesnt have the overflow tank. i know some 6gc have one but mine doesnt.
Oct 23, 2010 - 4:01 PM |
let the car cool off.
open the cap. turn the heat on high. start the car, add coolant as needed till full as the car comes up to temp. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 23, 2010 - 4:03 PM |
cool i will do that when it cools down, thankyou!
Oct 23, 2010 - 4:46 PM |
it also helps to raise the front end while you're topping it up.
Oct 23, 2010 - 9:36 PM |
Enthusiast Joined Oct 21, '10 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
hey everyone i just did a throtal body coolant bypass last night and lost a bit of coolant while doing it. i know low coolant can cause the car to over heat but what i accelerate the temp guage goes up and while im at a stop light. when im going along it stays where it should be, could there be a big air bubble in the system? and if so does anyone know how to get it out without draining the coolant. Open your radiator cap, and fill up the coolant, turn your car on and then continue filling - you'll fill it to the top, then wait a few seconds it'll go down again, fill it to the top again - once it doesn't go down anymore turn off and close your cap. Then there should be a plug on the lower backside of the radiator - loosen it a little until you see collant trickling out - wait until you see a steady stream coming out, close it back up and your all set. |
Oct 23, 2010 - 9:41 PM |
sweet i will try it! thanks.
Lo-Fi Version | Time is now: November 27th, 2024 - 10:08 AM |
