V_D's Custom Gas lid, k this is some stuff/problems i came across |
Oct 26, 2010 - 1:05 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
First it was the chrome gas cap that came with the gas lid. It was perfect until I started to hear hissing noises coming from the cap after a 30min drive, each and everytime. I pm'd him about it and he said give it time as it's still new. Sadly it didnt solve so i used my stock cap. I only use the chrome cap during car shows and meets.
How I came to recognizing the problem? After my daily commute I smelled gas and heard hissing noises coming from my cap. Then noticed my gas mileage dropped significantly. The noise is heard everytime the car was just turned off. Its like when you go to fill up gas and when you uncap the cap you get that HISSSSS noise from the back pressure. Second problem due to a faulty design, First occurance is by Herosblade. The spring mechanism to pop the lid after the lid switch is hit BROKE! Pretty much you pull the lever and your gas lid doesn't open. This is BAD! when you're by yourself and you don't have an extra hand and NEED GAS! This JUST happened to me as is the WORST feeling in the world when your gas light is on. You can't get the lid open, you're at the pumps that very moment and your house is 45mins away Temporary solution.....wedge something between the lid and the rear qaurter fender, pop the gas lever, and quickly catch the gas lid before it drops back into place T__T OR you can ask someone to pop the lever when you have your fingers pulling on the gas lid. I don't know how it broke in the first place as Im very careful with everything installed on the car except my coils SOLUTION!!! DO THIS BEFORE IT HAPPENS Simply get spring, mix some epoxy, and do as the pic is Problem solved. You will never be stuck at the pumps trying to get the damn lid open. I still haven't solved the gas lid problem, both Herosblade and I have taken off the chrome lid when daily driving our car. WE DO still use the chrome cap on special occasions. ********NOTE THIS THREAD IN NO WAY IS PUTTING V_D'S WORK DOWN. HE IS A PREMEIR 6GC DEALER. I'M JUST GIVING A HEADS UP TO EVERYONE WHILE PROVIDING SOLUTIONS********** I STILL SUPPORT HIS PRODUCTS AND I DONT MEAN ANY HARM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Oct 26, 2010 - 2:21 AM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
good to know i was thinking of getting one of these eventually
Oct 26, 2010 - 9:05 AM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
mine did the same thing with not wanting to open, fixed it a similar way, but never had the cap
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Oct 26, 2010 - 1:26 PM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
i just test fit my and it doesn't spring out too well...i have to use a flat to pry it out a bit...i left the stock on instead.
Oct 26, 2010 - 4:03 PM |
Enthusiast Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) |
Regarding the chrome cap issue, is the plastic O Ring still in place?
I don't mind to send you another chrome cap, if still encounter the same issue. Simply click here and find the one near ya http://www.mapquest.com/maps?state=HI&cat=Lottery+Agents The "Spring" on mine also broken, as no self-serve Gas station here in Hong Kong; I couldn't feel your pain. I admitted that fragile "Spring" have room for improvement Seems your modified Spring work way better than the one that supplier design. -------------------- |
Dec 31, 2010 - 2:45 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
exactly the same happened to mine so already removed it before i find solution
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Dec 31, 2010 - 5:34 PM |
had to fix mine again, when i popped it it would not open, ended up being the metal rod that it swivels on rusted so bad it wouldnt open, took it apart, sanded and lubed it, seems to work better.
wish my stock cap wasnt broken, i would go back to it -------------------- 1996 Toyota Celica Project Mean Green
Lo-Fi Version | Time is now: January 11th, 2025 - 1:45 PM |
