Advancing Timing |
Advancing Timing |
Oct 26, 2010 - 7:03 PM |
Enthusiast Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
ok, so ive found a topic on here that talks about advancing the timing on the 7afe... does anybody know what the timing marks are for this? ive searched as much as i know to search w/o any success. i understand that factory is at 10* and 15* is best bet for max power w/o hurting reliability.
Oct 26, 2010 - 11:18 PM |
because you have a 97 you cannot adjust your timing.
Oct 27, 2010 - 12:01 AM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
because you have a 97 you cannot adjust your timing. Why's that? OBDII? -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Oct 27, 2010 - 8:14 AM |
Oct 27, 2010 - 8:24 AM |
Im thinking it's because it's OBII as well because there are more sensors than the OBDI.
Lucky me that I have OBDI, but I need to convert the '97 engine that is going into my car to OBDI This post has been edited by mkernz22: Oct 27, 2010 - 12:36 PM |
Oct 27, 2010 - 8:56 AM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
Oct 27, 2010 - 9:19 AM |
the distributor is non adjustable, it just bolts into place.
in theory, you could slot the hole for some adjustment, but i dont know how the ECU would respond. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Oct 27, 2010 - 9:53 AM |
wait, so Manny, you're saying that I couldn't advance the timing if I convert the engine to OBI? or could I if I slot the hole?
Oct 27, 2010 - 10:15 AM |
wait, so Manny, you're saying that I couldn't advance the timing if I convert the engine to OBI? or could I if I slot the hole? if you swapped to a 94-95 ecu, and distributor, ecu, yes, you could. if you have a 96+, you'd have to slot the hole, but even then, i dont know if or how the ECU would respond to it. -------------------- Former Team 5SFTE pro member ;)
Oct 27, 2010 - 10:29 AM |
now i know why my mustang enthusiast friend wont have anything to do with fuel injection... he works strictly with carb, and pushes out as much power as possible w/o doing damage to the motor or adding forced induction
Oct 27, 2010 - 12:39 PM |
wait, so Manny, you're saying that I couldn't advance the timing if I convert the engine to OBI? or could I if I slot the hole? if you swapped to a 94-95 ecu, and distributor, ecu, yes, you could. if you have a 96+, you'd have to slot the hole, but even then, i dont know if or how the ECU would respond to it. Ohh I understand now. I'm definitely converting the '97 to OBDI. It's going to be a little bit of a process because I'm swapping the maunal engine/tranny harness onto the 97 engine, as well as the 94 ECU, and all the other parts that I will need as well to ceonvert it. I just need to get the other Celica first though lol |
Oct 27, 2010 - 12:51 PM |
why are you doing that if i may ask?
Oct 27, 2010 - 1:25 PM |
Advancing the timing or converting it to OBDI?
If you're talking about the timing, I just want to get a little bit more torque out of the car. If you're talking about converting it to OBDI, then it's because my car is already setup that way, and I'd rather it be OBDI than OBDII since there are less sensors. Also, the wiring harness that will be going onto the 97 engine will be from a manual 94 car and I just want the manual harness so that I won't have to splice any wirings together. I just want it to be very clean. |
Oct 27, 2010 - 1:34 PM |
u will spend more in gas than wat u get in power...
Oct 27, 2010 - 1:47 PM |
ohh, well no one mentioned that in any of these advanced timing threads, unless i skipped over something haha
Oct 27, 2010 - 1:49 PM |
u have to use 93octane to prevent knock and no one advances their timing because there is no benefit otherwise everyone would do it and there would be a write up etc
Oct 27, 2010 - 2:08 PM |
i remember reading that part of it, but yeah i guess it's not really worth itt
Oct 27, 2010 - 2:46 PM |
i read that the higher octane isnt really necessary until u hit about 18* or so... i was gonna go to 15*, but looks like i cant since the stupid OBDII... what was the point in that versus OBDI, i mean what do we need that OBDII has that OBDI doesnt have?
Oct 27, 2010 - 3:11 PM |
As for what I know, OBDII has more sensors and stuff like that. It also has a port inside of the car for when you go to inspection or just for the engine management stuff. So say if your airbag system isn't working, they would know on the OBDII because they have the plug-in unit, where as on the OBDI there is no port so they can only do a visual inspection. This is only what I know and heard so if you're looking for something specific, someone else on here will probably know alot more
Oct 27, 2010 - 4:56 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
OBDII Has NOTHING to do with toyota, all cars made/driven in USA had to swtich to OBDII 96+ and advance timing is useless on our cars it'll just give you a little better throttle response no mad 1000whp or anything its better on honda motors though I know from experience.
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Lo-Fi Version | Time is now: November 27th, 2024 - 12:31 AM |
