> HELP! oil in cylinders :(
post Oct 27, 2010 - 7:06 PM
5S-GTE
Joined Sep 3, '10
From CA
so the other day i pulled the plugs out of my 1997 celica's 5s-fe and looked at them and found some oil on the one in cylinder 2 kindasad.gif and ALOT of oil on the one in cylinder 4 frown.gif
im wondering what possible causes there are for oil to be in only cylinder 2 and 4 ..
1997 Celica GT
post Oct 27, 2010 - 7:56 PM
Spectorious
Joined Feb 24, '09
From Scranton, PA
deffinitly not in the correct place to be posting this question...but idk one of my plugs was oily when i took it out one time..car still runs though
post Oct 27, 2010 - 8:29 PM
blu94gt
Joined Mar 23, '05
From Kansas City
Was the oil in the cylinders, or in the spark plug tubes? If it's in the spark plug tubes then you just need to replace your valve cover gasket. If you're accumulating oil inside the cylinders in heavy amounts, well you have bigger issues.
1999 Celica GT
post Oct 27, 2010 - 10:37 PM
spark plug tubes (as previously stated) valve cover gasket is likely
inside the cylinders, sitting on top of the piston, valve seals/guides or piston rings
post Oct 28, 2010 - 3:09 AM
5S-GTE
Joined Sep 3, '10
From CA
ya the car still runs fine for the most part.. it just has a puff of blue smoke on start up then clears right up..
thanks for the tips.. ill double check on if it was just from in the tubes tomorrow, i just remember when i pulled plug 4 it was actually DRIPPING oil frown.gif
im hoping that its just a valve cover gasket.. not a head gasket or the valves or rings frown.gif dont wanna rebuild the motor just yet as i dont have the money..
1997 Celica GT
post Nov 4, 2010 - 1:55 AM
5S-GTE
Joined Sep 3, '10
From CA
replaced the valve cover gasket today and the tube gaskets.. those were pretty old and crusty looking.. so im hoping that that fixes the oil prob!! ill keep updated and tell ya if its all cleared up!
1997 Celica GT
post Nov 4, 2010 - 4:52 AM
Soulend
Joined Nov 24, '07
From Tucson, Az
my father (eventually passed it down to me) ran our car (also a 97 but an ST) for several years with a similar problem... it eventually started billowing out smoke... eventually this happened: http://www.youtube.com/watch?v=FTWFLFDgtow
so if you are having oil in your cylinders I'd suggest looking into at least getting a head gasket kit... it'll be a good amount of work, but it should help a bit. this will also give you a chance to look at the condition of the cylinders and pistons...
good luck,
Kevin
post Nov 15, 2010 - 3:09 PM
5S-GTE
Joined Sep 3, '10
From CA
just did a compression test.. the shop manual says its suppose to be 178.. but mine came out to be 180-190-190-190
so im guessing no blown head gasket or rings smile.gif but still oil in 2 and 4.. even after i replaced the valve cover gasket and the spark plug tube gaskets..
any ideas?
thanks
1997 Celica GT
post Nov 15, 2010 - 3:14 PM
5S-GTE
Joined Sep 3, '10
From CA
with the valve cover off..
1997 Celica GT
post Nov 15, 2010 - 5:48 PM
MrNate
Joined Nov 15, '10
From MA
Most likely valve seals. Not too bad to do yourself if you have the book, the right tools, and some mechanical inclination.
post Nov 18, 2010 - 9:30 AM
TerBeau
Joined Nov 25, '08
From dillsburg pennsylvania united states
pos head gasket if it smokes when u start it thats the oil burning up and blowing out.
those with golf balls golf
those with real balls race
Lo-Fi Version Time is now: November 25th, 2024 - 2:35 PM
