> Engine advice
post Nov 9, 2010 - 7:50 PM
beamer56
Joined Jul 23, '09
From Vermont
My '94 Cel has a 1.8 in it. Did a bunch on the engine when I put it on the road last spring. Great mileage but has bad rings and I'm not pulling it apart again.Just wondering if I can swap a 97 7afe in without too much trouble since the 97 has no distributor.
Thanks in advance.
post Nov 9, 2010 - 9:15 PM
d3ath2009
Joined Mar 26, '10
From Portsmouth, OH
well if u put in a new motor, it would be pretty pointless to not buy a complete motor in the first place. so theoretically, you should be able to just swap it out, although u may wanna go with 96 or older bc of the OBDI/OBDII issue
post Nov 9, 2010 - 9:18 PM
It does has a distributor.
post Nov 10, 2010 - 8:58 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Why wouldn't it have a distributor...
And it's cheaper and easier to just go in and replace the piston rings (and I'd also recommend replacing the valve seals while you're in there) than it would be to just swap another engine in. That other engine might have another problem you don't like. Fix what you know is wrong. And if you can't replace them yourself, it's STILL cheaper to pay for a mechanic to do it.
June '12 COTM
'95 AT200
post Nov 10, 2010 - 9:21 AM
its really not that much cheaper.
you can get used 7a's for a couple hundred bucks.
get the newer engine, swap over all your accessories, (harness, distrubutor, ect) and put it in and be done with it.
post Nov 11, 2010 - 5:25 PM
beamer56
Joined Jul 23, '09
From Vermont
QUOTE (HectortheRican @ Nov 10, 2010 - 8:58 AM) *
Because 97 up are aluminum block and they are Distributorless.
post Nov 11, 2010 - 5:37 PM
beamer56
Joined Jul 23, '09
From Vermont
QUOTE (beamer56 @ Nov 11, 2010 - 5:25 PM) *
I may be wrong on that assumption. I was told that 97 and up 1.8's were aluminum block and had no distributor. My mistake??
QUOTE (beamer56 @ Nov 11, 2010 - 6:25 PM) *
all the 7a motors are iron blocks.
post Nov 11, 2010 - 6:49 PM
beamer56
Joined Jul 23, '09
From Vermont
Lo-Fi Version Time is now: January 12th, 2025 - 2:42 AM
