> new wheels and tires, How do you think ?
post Nov 12, 2010 - 3:25 AM
whitewhisky
Joined Oct 25, '10
From Ankara - Turkiye
I bought new tires, How do you think ?
Wheel: OZ Futura
Front 17" -8" ET 35
Rear 17" - 9" ET 33
Tire : Kumho
215/45/17
235/40/17
Celica from TURKIYE
post Nov 14, 2010 - 12:21 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
cool wheels, I like the dish look
I will return one day.
post Nov 14, 2010 - 2:11 PM
dudeofchaos
Joined Dec 9, '08
From Blainville
Was it hard to fit 235's in the rear and 215's in the front? I'm planning to get 225's front and 245/255's in the rear so.. wink.gif
Guess you rolled you fenders and use spacers?
This post has been edited by dudeofchaos: Nov 14, 2010 - 2:14 PM
post Nov 14, 2010 - 2:51 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Good flushness! Now just roll the rear fenders and down she needs to go!
June '12 COTM
'95 AT200
post Nov 14, 2010 - 3:44 PM
epocsirhc
Joined Nov 8, '08
From Penn Valley,Ca
I like those wheels alot!
post Nov 14, 2010 - 6:56 PM
king_toyo95
Joined Nov 14, '10
From san antonio tx
smile.gif looks sweet
[font="Garamond"][/font]KING
post Nov 15, 2010 - 4:26 AM
whitewhisky
Joined Oct 25, '10
QUOTE (dudeofchaos @ Nov 14, 2010 - 9:11 PM) *
my spec ;
front: 215/45 - sidewall 96.8 mm
reaer: 235/40 - sidewall 94.0 mm difference 2.8 mm GOOD
front: 215/45 - diameter 625.3 mm
reaer: 235/40 - diameterl 619.8 mm difference 5.5 mm NOT BAD
Your plan;
nice combination
front: 225/40/17 - sidewall 90.0 mm
rear: 255/35/17 - sidewall 89.2 mm GOOD
front: 225/40 - diameter 611.8 mm
reaer: 255/35 - diameterl 610.3 mm GOOD
tire size combination used for this link:
http://www.miata.net/garage/tirecalc.html
my fenders original and no use spacers, because I'm using the rear wheels et33 and 9" width
Celica from TURKIYE
post Nov 15, 2010 - 12:07 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
looks super good, glad to know that this setup works since i am planning on eventually doing 17x9 +30 rear and 17x8 +35 front.
rear looks super flush, front needs 10 mm spacer (+25 offset)
post Nov 16, 2010 - 10:55 PM
Ted95
Joined Mar 8, '09
From Westport, MA
looks dope bro! just need to rock that thing and it will look so sick bro
st205 powered ss3 coupe
post Nov 17, 2010 - 8:21 AM
Makabra
Joined Apr 16, '10
From Poland
Consider byuing hidden valve stems. Would look better thant sticking out ones. Im planing to get these for my wheels smile.gif
post Nov 17, 2010 - 2:00 PM
whitewhisky
Joined Oct 25, '10
QUOTE (Makabra @ Nov 17, 2010 - 3:21 PM) *
interesting, good idea. Where do I get? I don't see in Turkey
Celica from TURKIYE
post Nov 27, 2010 - 9:18 AM
Makabra
Joined Apr 16, '10
From Poland
I dont know. Search on ebay or something like that. Maybe local shops with car accesories
post Nov 27, 2010 - 10:40 AM
how do u use them
post Nov 27, 2010 - 10:31 PM
Greyform
Joined Nov 18, '10
From Santa Rosa, CA
those look pretty dope man,
post Nov 28, 2010 - 4:51 PM
quick_5hifter
Joined Mar 13, '09
From Constanta, Romania
I like the wheels alot!
I've just bought a set of similar ones for my car too and I was wondering how will they look with the proper tires...
The old 18" wheels were too unconfortable because they required 215/35/R18 tires, the car is pretty heavy and the romanian roads are severely damaged.
The only problem is that I will probably need wheel spacers on the front, since they are all 8,5 or 9 inch wide, but the front has a smaller ET and will probably hit the strut (haven't tried the front yet).
How does the car handle with the new wheels, compared to the original 15" ones? Is acceleration better or worse? Are the new rims, together with the tires, heavier than the original steel ones?
I'm going to buy 215/40/R17 tires for all the wheels, I user another tire size calculator and that is the best tire size for no speedometer differences (must check if the tires will fit the rim width)
Hope you don't mind if I add a couple of pictures with my "new" wheels:
post Nov 29, 2010 - 4:49 AM
whitewhisky
Joined Oct 25, '10
Which one you going to use 8.5 or 9 width
ET size are important here, what is the ET size of your wheels ?
If use ET 33 or 35, width 8.5" (215/40/17) nice combination. You do not need to speacer
I would like to see the final version
Celica from TURKIYE
post Nov 29, 2010 - 11:14 AM
quick_5hifter
Joined Mar 13, '09
All the wheels have the same J (width), which is exactly 22,5 cm, which is approximately 9 inches, measured from the outside of the wheels.
Nothing is written on my wheels, no J, no ET, so I don't know very much about them biggrin.gif (actually I didn't check under the center covers...)
There is no problem with the back wheels, but I didn't try the front ones yet.
Anyway, I'll figure out a solution for the wheels, but probably in 2-3 months, when I'll buy the summer tires. After that, I will add one more picture here, if you don't mind biggrin.gif
post Dec 12, 2010 - 4:52 PM
derick_swain
Joined Dec 12, '10
thous are SICK!! looks like some thin you would see on a muscle car biggrin.gif
Lo-Fi Version Time is now: February 18th, 2025 - 8:29 PM
