Project Taurus, Engine ready |
May 25, 2012 - 2:08 AM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
currently yes but we are testing a electrolytic internal polishing process on the manifold you sent to me greetz -------------------- |
Jun 4, 2012 - 11:30 AM |
Hi,
took some time to polish and calculate the volume of the combustion camber, ~48mL and the shortblock should be back to me the next few weeks http://www.rallye-engine.com/ here some pichtures of his work http://www.rallye-engine.com/index.php?opt...s&Itemid=54 greetz -------------------- |
Jun 8, 2012 - 12:45 PM |
Hi,
the engine arrives today - 86,25mm pistons verbauen - everything balanced - everything weight mached - 3 layer TRD bearings (complete engine) - repaired crank becouse the crank seal damages the sourface - 0,05mm decked and the next is to calculate the volume too to get the CR and then i will slowly begin to assemble everything together greetz -------------------- |
Jun 10, 2012 - 6:04 AM |
Hi,
calculated CR is 8,8:1 greetz -------------------- |
Jun 11, 2012 - 10:34 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
im patiently waiting to see this build complete, great work so far man im excited to see your next update!
-------------------- st205 powered ss3 coupe
Jun 11, 2012 - 10:43 PM |
Enthusiast Joined Apr 1, '11 From rochester ny Currently Offline Reputation: 0 (0%) |
awesome dude its all shiny great job
Jun 12, 2012 - 3:09 PM |
Hi,
thanks folks the buttom is finished i had to grind a little bit to get enough space for the blacktop oil pump, but nothing dramatically greetz -------------------- |
Jun 25, 2012 - 6:33 AM |
Hi,
lets have a look how much i can do this week, everytime that little problems like the correct key for the arp studs and i foudn a little space problem by the injector connectors and the rail so i have to grind a little bit a intercooler is also on the way to me to solve the biggest question, what type of valvecover fit well...... but time heals every wounds greetz -------------------- |
Jun 26, 2012 - 12:47 PM |
Hi,
little modified fuel rail so that the injector plugs fit and then the bigger problem, clearly visible that it is not easy to make the turbo fit the intercooler especially when it shoult professionaly, but the good point is that the ST246 valvecover looks like that throttle body and ic line up well greetz -------------------- |
Jul 17, 2012 - 11:39 AM |
Hi,
small update, the timing belt is mounted and works and here a adapter plate for the ISC, in the future i will work with a haltech ISC looks like i come in trouble with the water inection valve.....this valve is also a troublemaker, the oem nozzle is to small in size so i had to bore them until i hit ~350mL/min, the big issue is that not the nozzle itself limit me but the valve seat, so i had bo cut the nozzle bore the valve seat, weld it together and then i can machine the nozzle to hit my target possible i do theis on weekend mfg Alex -------------------- |
Jul 17, 2012 - 4:25 PM |
Gute arbeit, viel glück. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Jul 17, 2012 - 7:26 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
amazing stuff sunny!
Jul 18, 2012 - 6:37 PM |
Hi folks,
thanks, hope for a further update in the next few days greetz -------------------- |
Jul 19, 2012 - 7:11 AM |
damn spambots, what intercooler did u order sunny I am looking for another one but I am scared it wont fit like the last one i ordered
Jul 19, 2012 - 7:24 AM |
Hi neon,
i use a uprated TTE group A spec intercooler on top of the engine - custom pre radiator - jabsco 80L/min pump -TTE swirlpot fuel cut when it is cold outside even without boost controller best regards Alex -------------------- |
Jul 19, 2012 - 11:58 AM |
Assuming that's the name of your mechanic, I hope it holds true. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Jul 19, 2012 - 1:23 PM |
Hi,
thats me lol greetz This post has been edited by Sunny: Jul 19, 2012 - 1:25 PM -------------------- |
Aug 4, 2012 - 4:37 PM |
Hi,
a few more little bits are done a M5 thermocouple takes place, the problem was the M6 thread in the manifold so we gave'em a machining here takes a AN8 fitting his place, truely a master of welding to get the fat fitting on the 0,8 pipe, respect here i will built a heat shield and the next steps are fuel press regulator and ISCV greetz This post has been edited by Sunny: Aug 6, 2012 - 6:46 AM -------------------- |
Aug 6, 2012 - 12:56 AM |
sick sick build man! mucho respect!
Aug 6, 2012 - 8:29 AM |
Ah I see that NSK bearing on the timing, I was unsure if it would work because it has a diff bracket. Good to see it installed on yours! So now I know its good to go!
Progress looks fantastic! |
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:29 PM |
