13 Pages V  « < 6 7 8 9 10 > »
> Project Taurus, Engine ready
post Nov 25, 2012 - 11:24 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
and tomorrow i will weld it to the manifold
greetz
KEEP COOL UNDER PRESSURE
post Nov 27, 2012 - 4:17 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
the manifold is ready, the job was a little paine of work, high temp cracks on the welding and pretty hard to deck, but all in all ready to mount/ test fit
greetz
post Nov 28, 2012 - 8:43 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
and here the first mounting
hte new engine also uses a new oil thermostat which also have sensor ports to safe some space down to the undertray
greetz
post Nov 28, 2012 - 11:48 AM
bsamps4
Joined May 16, '10
From Raleigh
Where did you buy the oil filter adapter and the gold fittings?
post Nov 28, 2012 - 1:14 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
greedy usa
http://www.shopgreddy.com/accessories/engi...-4-x-16unf.html
hope it helps
greetz
post Nov 29, 2012 - 3:32 PM
Ted95
Joined Mar 8, '09
From Westport, MA
st205 powered ss3 coupe
post Nov 29, 2012 - 5:41 PM
Neon90424
Joined Jan 19, '11
you sick sick man you!! tongue.gif looks awesome... I was getting 1.8 bar of boost in 1st and 2.4 bar in 2nd...so I hope you have a good boost controller...I had alot of baby drama with the internal boost controller on the eFR
post Dec 1, 2012 - 10:18 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
thanks folks, i will controll the boost with the haltech ECU so there should not be so much problems, does i ask you for your problems and how you set the actuator spring?
2,4bar.....we calculated the boost to 1,5-1,6bar, how much hp did you get?
greetz
post Dec 1, 2012 - 1:41 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
der IC is raised 14mm to get space for the cops
and here the ic pipework issue
greetz
post Dec 8, 2012 - 1:29 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
two new pictures, the oil lines are done
AN4
AN10, here i have to correct the fitting angle to get the S out of the line
greetz
post Dec 11, 2012 - 8:00 AM
Ted95
Joined Mar 8, '09
From Westport, MA
thats such a hard bend coming off the turbo kindasad.gif what are your plans for the IC connection?
This post has been edited by Ted95: Feb 25, 2013 - 12:16 PM
post Dec 11, 2012 - 8:38 AM
RoyO
Joined Jan 8, '09
From Netherlands
You did an amazing job again! Are you going to isolate the IC?
post Dec 11, 2012 - 10:14 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
i will correct the angle later when i did a new IC piping to fit the turbo air outlet (my heard is bleeding becouse it is a TTE IC but it is the only way)
no, the IC itself did not become a isolation only the turbocharger becomes some new heatshields
that legs are from a puppet, but do not think anything crazy from me the garage is not my one.....truely biggrin.gif
greetz
post Dec 19, 2012 - 3:07 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
hopefull the last revision to the fuel system
i'am just pending about i should use the damper
greetz
post Dec 19, 2012 - 3:17 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Looks like you need to clock the turbo a bit more and build one hell of hot pipe. I have faith you can do it! biggrin.gif
post Dec 20, 2012 - 6:06 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
greetz
post Dec 31, 2012 - 6:45 PM
Neon90424
Joined Jan 19, '11
Hey sunny what was the reason for the black top oil pump? I am going to buy a ST215 engine and build it nice and slow like you did, and planning to rev it pretty high.
I had problems with fitment and made a custom adapter for the internal wastegate. But I kept having low boost so I ended up scrapping the internal wastegate setup, permanently shut it and went with the OBX external wastegate...have to change the 21 psi spring though because we cant control the boost.
This post has been edited by Neon90424: Jan 1, 2013 - 3:20 PM
post Jan 1, 2013 - 2:52 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
that pump has the highest oil flow
be carefull, with the rpm llimit, 23m/sec is a critical point for the piston speed, from that on abrasion raises
hopefull i have not that problems with the boost, currently i set the spring to 6turns
greetz
post Jan 1, 2013 - 3:21 PM
Neon90424
Joined Jan 19, '11
and what rpm is that sunny? i don't really under stand the 23m/s
do you have a part # for that pump?
This post has been edited by Neon90424: Jan 1, 2013 - 3:22 PM
post Jan 2, 2013 - 9:09 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
8000rpm at 86mm stroke = 22,93m/sec
the part number is 15100‑88570
http://www.toyodiy.com/parts/p_J_2003_TOYO...AEFVF_1501.html
note that these pumps aren't interchangeable to gen.3 engines becouse they are built to utilise crank position sensors, oil pan nr.1 is different to make space for that sensor
the new gears are here
a comparison to the old ones
the gears are great,
- 10mm head against a allen key
- granate pin
- two further wholes for a key to turn the camshaft
love them, hope they fit :lol:
greetz
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 27th, 2024 - 3:19 AM
