Project Taurus, Engine ready |
Jan 2, 2013 - 5:06 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
I was going to use it on a 4th gen actually...the one that has COP and uses the crank pos sensor
Jan 2, 2013 - 6:05 PM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
got it, so she is nearly plug&oplay, you just habe to grind the block a little bit, nothing dramatically greetz -------------------- |
Jan 2, 2013 - 9:27 PM |
yeah that will be interesting...loong way to go I have to purchase the block first and wait 3 months for it to get here though...
Jan 2, 2013 - 11:37 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
Cam gears look great sunny! Which cams are you running again, did you stick with stock or something with more lift?
-------------------- st205 powered ss3 coupe
Jan 3, 2013 - 8:38 AM |
Hi,
Catcam in belgium did some custom cams to my requirements, i bought the a whole set with springs cams and gears > - intake camshaft: #3180: 269°@0.1mm/235°@1.0mm/11.51mm/2.43mm@108°/vc > 0.250mm > - exhaust camshaft: #3175: > 249°@0.1mm/215°@1.0mm/10.26mm/0.56mm@-116°/vc 0.250mm so, a little more lift then stock :-) greetz -------------------- |
Jan 3, 2013 - 2:16 PM |
why not just 272 cams?
Jan 3, 2013 - 4:08 PM |
Hi,
there are a few reasons, - the cams effects the engine characteristic dramatically, i wanted some that fit my aplication - the price for the whole package was the same price as bought ready from market - the gen.4 engine uses a different intake cam with cam position trigger on the end greetz -------------------- |
Jan 3, 2013 - 8:10 PM |
do you still need the cam pos trigger with an aftermarket ECU? I thought the head was the same as the 3rd gen head...
Jan 4, 2013 - 8:23 AM |
Hi,
yes, i'am in need of the sensor, without the ecu isn't able to fire the correct cylinder 1-4 or 2-3 no, the gen.4 head differs, on the gen.3 you have just bolts for the IC bracket and on the gen.4 you have the cam position sensor mounting, that was the reason for my custom mounting i built for the IC and engine hangar (have a look to the picture of the last EFI modification) greetz -------------------- |
Jan 4, 2013 - 9:27 AM |
your ecu doesnt use a crank pos sensor? I had to make on for my engine for the ECU to know when to make the dizzy fire.
Jan 4, 2013 - 3:19 PM |
Hi,
my ecu also needs the crank sensor, the gen.4 has a different timing belt pulley on the crank which is also the triggerr wheel for the sensor which is mounted on the oil pump gen.3 = both cam and crank sensor is intigrated to he dizzy gen.4 = crank on the oil pump and cam position in the head/intake cam greetz -------------------- |
Jan 6, 2013 - 5:08 PM |
Enthusiast Joined Jan 5, '13 From Florida Currently Offline Reputation: 0 (0%) |
This is car porn and should be in a magazine haha. Terrific work. I like that you have taken your time to calculate everything and focused more on the engine rather than body mods. Can't wait to see it finished!! Also you need to upload video so I can hear this thing pur when you're all done.
Keep up the good work. |
Jan 7, 2013 - 9:37 AM |
Hi,
omg, thanks a lot greetz -------------------- |
Jan 8, 2013 - 12:12 PM |
Hi, Catcam in belgium did some custom cams to my requirements, i bought the a whole set with springs cams and gears > - intake camshaft: #3180: 269°@0.1mm/235°@1.0mm/11.51mm/2.43mm@108°/vc > 0.250mm > - exhaust camshaft: #3175: > 249°@0.1mm/215°@1.0mm/10.26mm/0.56mm@-116°/vc 0.250mm so, a little more lift then stock :-) greetz sweet deal, now where would expect to see the power band increase with these cams? probably small gains in mid range and bigger gains up top in the rpms right? -------------------- st205 powered ss3 coupe
Jan 8, 2013 - 5:27 PM |
Hi,
pretty nice appraised, max. touque from latest 4000rpm up to 7500rpm this was set years ago, and now the absolute famoused that occures to me, when borg warner released the EFR series i saw that the 6758 hit my application perfect, lol or 90% perfect, everything was around a twin entry turbo and then i got the message from BW that the small frame EFR do not use this......was not a reason to say no a small update tomorrow...... greetz -------------------- |
Jan 16, 2013 - 7:56 AM |
Jan 16, 2013 - 10:47 PM |
Efr 7064 I think I might have the numbers wrong...is twin entry... and It comes to boost so quick my mech. told me he would have actually bothered with the 500-550hp version of the EFR
Jan 18, 2013 - 8:33 AM |
Hi,
thats the B2 frame which is twin entry available, i thought you use the 6758 (B1)? do you have a picture of the number plate on the compressor housing? greetz -------------------- |
Jan 27, 2013 - 6:37 AM |
Hi,
yesterday the work goes on, i built the water lines nearly ready, nearly becouse i have to weld in a bracket to connect both lines so that no motion is possible, unfortunetly i have to built a two peace bracket connected with a screw so that a later dismounting is possible greetz -------------------- |
Feb 23, 2013 - 7:15 PM |
Hi,
today it goes on, nearly ready mounted setup except the TB, i still have to dismount her becouse of the wiring tree the oilcooler becomes a heat shield, the turbo actuator currently has one and then i have to built one for the top of manifold and turbo greetz -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:17 AM |
