Project Taurus, Engine ready |
Feb 1, 2012 - 1:16 PM |
Enthusiast Joined Jun 5, '07 From Santa Maria Currently Offline Reputation: 1 (100%) |
Looks awesome!
Feb 4, 2012 - 7:00 AM |
Enthusiast Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
thanks mate, will do a update once some more parts arrived me greetz -------------------- |
Feb 9, 2012 - 4:39 PM |
Enthusiast Joined Jan 21, '07 From Harrogate England Currently Offline Reputation: 0 (0%) |
Hey there,
First can I say well done with your project looks great. I'm planning on moving my battery to the boot. What do I need and what size cable do I need? Thanks Ed |
Feb 10, 2012 - 1:59 PM |
Hi,
thanks a lot for your compliment, you need the following parts have a look to this homepage http://www.gtfours.co.uk/ -> how too -> relocate the battery if i remember correctly i'am using a 35mm² wire and a 120A fuse on the battery (-> RS-components fuse holder) hope it helps greetz -------------------- |
Mar 2, 2012 - 2:17 PM |
Hi,
today more parts arrived 86,25mm, CR=9:1, ~334g and the h-beam conrods, ~584g nearly to shiny to built in, possible i give them in the glass cabinet :lol: next on the whis list is the turbo and then i hope that i can built everything together as easy i dismounted all greetz -------------------- |
Mar 3, 2012 - 6:10 AM |
Enthusiast Joined Jan 8, '09 From Netherlands Currently Offline Reputation: 54 (100%) |
Mar 3, 2012 - 9:43 AM |
Hi,
it is still a option for me greetz -------------------- |
Mar 21, 2012 - 8:17 AM |
Enthusiast Joined May 21, '06 Currently Offline Reputation: 0 (0%) |
Hi Sunny.
Your project is perfect,but why you didn't buy WOSSNER pistons and WOSSNER connecting rods?They have lower weight. |
Mar 28, 2012 - 11:53 AM |
Hi,
sorry for the late reply and thanks for you compliment i had a few phone calls to wössner, and i also compared the weight there isn't a big difference but iirc CP-Carillo was a bit lower in weight i think it simple was a matter of taste why i decided to go with CP-Carillo, or possible the fact that a good friend drives wössner in his engine and i want something different to bring some color in the game .....hope for some updates soon greetz This post has been edited by Sunny: Mar 28, 2012 - 11:59 AM -------------------- |
Apr 2, 2012 - 12:37 PM |
Hi,
small update, uprated oem water pump the following two pictures shows the axial clearance without gasket oem, is ~2mm + 0,5 for the gasket and here the machined one, 0 clearance without gasket (target clearance of 0,5mm with gasket) i also machined all edges, good to see the two angles of the oem plastic impeller pump seat and here a comparison of the two different pump housings, gen.3 GTE with the two angle seat and gen.4 with the simple one angle stainless variant and here a how to do, all 3S engines from gen.3 onward uses the simple stainless pump except the gen.3 GTE i found that the stainless pump housing has enough material to machine the two angle seat at the target clearance so you need both housings, one where you get the angels measured and stainless pump housing to machine it we did it on CNC turning machine, and was in need to built a bracket becouse the housing isn't able to get fixed centric without, then we measured the angles and programmed it it takes ~2hours and cost me 100€, absolute ok i think feel free to drop me any question if needed greetz -------------------- |
Apr 4, 2012 - 7:17 AM |
Hi.
I'm sorry,but the h-beam CARRILLO conrods, ~584g the h-beam WOSSNER conrods, ~495g |
Apr 4, 2012 - 11:58 AM |
Hi,
nearly 100g, nice but to late for me greetz -------------------- |
Apr 5, 2012 - 11:31 PM |
Enthusiast Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
I want that aluminum panel that bolts under engine bay looks so nice!! Great build can't wait to see it all come together. Patience is a necessity but it looks like its coming together great! A+ work on all custom pieces
Apr 6, 2012 - 2:19 AM |
You've done nice custom work again!! I'm very curious about the rest of the build..
Apr 9, 2012 - 5:27 AM |
Hi, Roy,
thanks, it was that housing you sent to me so one more thank you greetz -------------------- |
May 19, 2012 - 4:52 AM |
Hi,
just some small things are done some high heat screws for the manifold and a selfmade tower bar, so it is easier for me to weld on mountings if i'am in need a bigger update soon once the block is back from the builder maschined intake manifold to fit the smaller haltech IAT thread greetz This post has been edited by Sunny: May 19, 2012 - 6:05 AM -------------------- |
May 19, 2012 - 9:31 AM |
Excellent work, this is continually impressive & interesting. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
May 22, 2012 - 10:08 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
lookin good man, this will end up being a beast of a car
-------------------- st205 powered ss3 coupe
May 24, 2012 - 2:27 AM |
Hi,
thanks folks greetz -------------------- |
May 24, 2012 - 3:56 PM |
Interesting upgrades as usual Nice update on the intake manifold! That's the only modification you've done to it?
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:02 AM |
